?? technical question about gearing
Old May 14, 2005 | 10:38 PM
wildchevy's Avatar
wildchevy
Default ?? technical question about gearing
I need someone who is technically inclined to lend a hand.
My C5 is a 6 spd with 343 gears and 345 tires (27.4" tall),
the car came with tires that were 26.8" tall
I now have to go to a 335/30/18 tire as the 345 is dicontinued
at any rate, the 335"s are 26.1" tall
so my question is... what gear ratio am I currently running considering I have tires that are taller than the stock ones?
AND... what gear ratio will this equate to when I run a shorter tire?
ALSO... let's say that I now run 1500 RPM at 70 (6th gear) and I want to run about 300 more RPM. What gear do I need to put in the car?
Thanks for your help! I really need it!
Old May 14, 2005 | 11:06 PM
6Speeder's Avatar
6Speeder
Even though those size changes sound big, they really were only about 3% each. Your 3.42's acted like 3.33's with the tall tires, and will pull revs like 3.50's with the short tires. If you want 1800 rpm with the new short tires you will need to run 3.90:1 rear gears. Hope this is what you are looking for.
Old May 16, 2005 | 01:37 PM
wildchevy's Avatar
wildchevy
Thanks Wayne! That's exactly what I needed to know.
To ?? technical question about gearing
