Hardwire Battery Tender
Old May 22, 2005 | 10:47 PM
s200's Avatar
s200
Default Hardwire Battery Tender?
Has anyone hardwired their Battery Tender? By hardwire I mean connected the Battery Tender ring connectors right to the battery. I tried to do it yesterday and discovered that I could not fit the ring connectors between the battery and battery cables. So I started to look around and discovered a possible solution.
There is terminal on the fuse box that has a cable that leads right to the battery’s positive post and another on the chassis that has a cable that runs to the battery’s negative post. In the photo below I have laid the Battery Tender cable onto the two terminals that I referenced to illustrate. Is this a good solution? Any reason not to do it this way?
Thanks for your help!
Old May 22, 2005 | 11:22 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
That ought to work. I just bought some after-market terminal screws that are piggy-backed so you can add other connections.
