Spark plugs/Wires?
Old May 25, 2005 | 04:02 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Spark plugs/Wires?
What kind of spark plugs and wires do you guys use?? MSD?? What gap are you putting them at?
Old May 25, 2005 | 04:05 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
MSD and NGK TR55s. Gap was at .52 or .55 if I remember right.
Old May 25, 2005 | 04:08 PM
QuikZilver's Avatar
QuikZilver
I just replaced mine with AC Delco Iridiums (factory-style). It had Densos in it. Gap for AC Delco Iridiums: 0.040". As for wires, I got a set from Mid America (inexpensive set) made with Packard wiring in Blue. Got them just to dress up under the hood a little. They were $40 for the set. Eventually, I'll go with better wires.
Old May 25, 2005 | 04:13 PM
VA CORVETTE 757
i'm thinking about the 8mm taylor spiro or the 8.5 MSD......
Old May 25, 2005 | 04:21 PM
Monster231's Avatar
Monster231
those are both very good products. I opted for the MSDs they have been good to me. I also went with NGK's but im having some ignition problems now. Im not sure that its the plugs, its probably a coil
Old May 25, 2005 | 04:22 PM
MHVette's Avatar
MHVette
I run the same setup! Nothing but Miles & Smiles
Old May 25, 2005 | 05:15 PM
MY03Z's Avatar
MY03Z
stock wires ngk plugs. No need to change the wires unless there are bad or you want to change the color.
Old May 25, 2005 | 09:24 PM
magredZ51's Avatar
magredZ51
GMPP Hotwires are only $61 dollars a set at dealer. They are red and
and use the oem ends. NGK TR55's. Everyone gaps theirs different
depending on mods and personal preference. Range .050 to .060.
Old May 25, 2005 | 09:49 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
TR55s and Taylor 10.4mm wires.
To Spark plugs/Wires?
