Pulled battery, now engine cranks, but no fire.
Old May 26, 2005 | 02:31 PM
Dr. Dirt's Avatar
Dr. Dirt
Default Pulled battery, now engine cranks, but no fire.
Ok guys, I need some help. Some idiot (me) drained the battery. I pulled the battery out of the car to charge. Put the recharged battery back in the car. Now the electical system seems to be functioning right and the car cranks just fine. But I get some initial fire out of the engine and then nothing, like no more fuel or no more spark.
I know I have seen something similar here in the past but can't find it. So do I need to pull a specific fuse, follow some rebattery procedure, or something much worse. (please no computer please no computer)
Thanks is advance.
Old May 26, 2005 | 03:35 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I would guess something fuel pump related. Try turning the key from off to 'run' a few times and see if you can hear the fuel pump running. I'm not sure of which fuse you speak of, but obviously you should check over them all if you think that's the problem. I'm not sure how the fuel pump is triggered after the engine is running but to me, that sounds like the problem.
You sure there's enough gas in it?? I ran out with the gauge on "1/4" tank one time...and pretty much anytime I'm under 1/2 tank it takes a good 4-5 seconds of turning the engine over before it starts up.
Old May 26, 2005 | 04:12 PM
Dope's Avatar
Dope
Resident moron
Sounds very familiar to my issue I had a year back or so. Unfortunately someone deleted all the old posts on the board it appears, so I can't find the thread.
Is it setting any codes? Check and make sure. Give me the codes if it does come up. Your BCM may not be synched with the PCM anymore.
Dope
Old May 26, 2005 | 05:43 PM
Sorry I Bought An A4's Avatar
this exact thing happened to me. my computer was shot. gm warranty covered the install of the new one.
Old May 27, 2005 | 12:08 PM
Dope's Avatar
Dope
Resident moron
Any word?
Dope
Old May 27, 2005 | 12:09 PM
Dr. Dirt's Avatar
Dr. Dirt
Ok this brings up a good question, how do I check my codes? After the fuses (no luck) and gas (full tank) that is probably a good place to start.
Old May 27, 2005 | 02:11 PM
Ron71's Avatar
Ron71
Turn ignition to first on position. Push reset to clear any text on column. Press and hold Options and then press Fuel 4 times. This will be make the codes list out if I am remebering this correctly.
Old May 27, 2005 | 02:26 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
^ that's correct...
Old May 27, 2005 | 02:56 PM
Dr. Dirt's Avatar
Dr. Dirt
Thanks, will try soon.
Old Jun 1, 2005 | 10:49 AM
Dr. Dirt's Avatar
Dr. Dirt
Ok, I pulled the codes and a whole bunch showed up. I am guessing the H’s are historical codes and the C is the current code. If that is the case, the only current code is the PCM code. Here is the list, maybe you code guys can tell me what they mean.
10 PCM: P1631 H C
28 TCS: C1255H
L10BCM: B0432H
B0502H
B0503H
B0507H
B0508H
B2482H
AOLDCM: B2282H
B2284H
U1064H
A1RDCM: B2283H
B2285H
A6SCM: B0851H
B0 RFA: U1255H
Old Jun 1, 2005 | 12:59 PM
Dope's Avatar
Dope
Resident moron
Ah yes, 1631. That's the same problem I had when I stored my car for the winter without the battery. Same symptoms too. Cranks fine, fires once immediately and that's it.
From what I understand, it's caused by a loss of synch between the PCM and the BCM. To re-synch manually, you have to:
Turn ignition on (do not start) for 11 mins or longer.
Turn off for 30 seconds or longer
On for 11 mins
Off for 30 seconds
On for 11 mins
Off for 30 seconds
Try to start it. I bet it'll work. If you screw up any part of the process you will have to start over. The times listed are a MINIMUM. As long as you do at least 11 mins/30 seconds minimum, you're fine.
Unfortunately, ever since this incident, unplugging the battery, even for a moment, causes the synch to be lost. I have never figured out the cause. I just don't disconnect the battery anymore. I figure replacing the BCM will probably fix it, but I don't feel like doing that I just hook up a battery tender in the winter now and it's been fine.
My theory is that the problem is like a BIOS battery in a computer. It stores the system's settings when you unplug it from the wall. I think there's some sort of similar backup battery in our cars, that if you disconnect the main battery for long enough, will cause the backup to die.
I had a big thread on this on a few boards, when this happened 2 years ago, and no one had any clue.
Dope
Old Jun 1, 2005 | 01:53 PM
Dr. Dirt's Avatar
Dr. Dirt
Dope
Yea, that's it alright. Dope you ROCK! I won't be able to try this tonight, but should be able to do it Thrusday night. I will let you know how it goes.
What a crazy procedure, but if it works, it will be the best hour I ever wasted. Thanks for the heads up on the problem cropping up in the future. Will expect it if my battery gets disconnected.
Bill
Old Jun 1, 2005 | 03:37 PM
Dope's Avatar
Dope
Resident moron
No problem. Be sure to post an update.
Dope
Old Jun 3, 2005 | 09:46 AM
Dr. Dirt's Avatar
Dr. Dirt
Hey Dope,
Here is your update. After following your resync procedure, car fired right up last night. No problems today and I am back to driving the vette. Who knew how much I could miss that car after only a week. So thanks once again, saved my wallet and my pride.
Old Jun 3, 2005 | 11:13 AM
Dope's Avatar
Dope
Resident moron
No problem Bill Enjoy!
Adam
Old Jun 3, 2005 | 10:20 PM
naturalgas's Avatar
naturalgas
that's good stuff
Old Jun 3, 2005 | 10:48 PM
csexton's Avatar
csexton
Great forum members come through again!!
To Pulled battery, now engine cranks, but no fire.
Old Jun 3, 2005 | 11:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a broken BCM and have disassembled it. There is nothing in it that would save the memory battery wise. There are what looks like two capacitors but nothing like a battery. It anything like that exist, it must reside in the PCM. I would like to get my hands on a bad one and disassemble it!
Dope
EXCELLENT advice!!
Bill C
Old Jun 4, 2005 | 12:27 PM
jmesox's Avatar
jmesox
I wish I had seen the thread. No one answered my thread listen to my story. I think the solution that you got would have solved my problems. Here is my story.
I disconect my battery this weekend reconnected it and my DIC went crazy. Disconnected and reconnected the battery DIC was fine. I did not do any electrical work. Today I put the airconditioning on and the driver side was hot and the passenger side had cold air. After I tried looking in the manual for something simple I could do easily. I disconnected and reconnected the battery with the air off everything works fine. Does any one have a clue what happened? I happy but confused.
John
PS: Never diconnect your battery
Old Jun 4, 2005 | 03:17 PM
Dope's Avatar
Dope
Resident moron
Dope
EXCELLENT advice!!
Bill C
Thanks Bill
I wish I knew what was causing the problem too. I'd hate to spend the $$ to replace the PCM and the BCM and such, especially with the need for reprogramming. I just leave my battery connected and I'll just have to re-synch every 5 years or so when I get a new battery.
Dope
