Hurricane or Blackwing?
http://www.conceptualpolymer.com/Rad...op%20inst..pdf
I originally machined a PVC scoop and was almost ready to install it when the forum member suggested an unbreakable wall pocket from Staples Office Supply for $8. I figured that most C5 owners who want cold air would not be able to machine a scoop or pay to have someone do it, so I opted for the wall pocket. It turns out that it is the perfect size and doesn't impede flow to the radiator (at least from my data and observations).
In case the above link doesn't take you to the procedure, click here for a list of that one and others, like installing the Halltech Stinger and a BPP short shifter: http://www.conceptualpolymer.com/corvette_c5_corner.htm
By the way, as you can see in the procedure, I made the radiator cover cutout a bit small. That part was done in anticipation of using my PVC scoop and when I decided to use the unbreakable wall pocket, the screen was already trimmed to fit the PVC scoop. Those of you who do this mod can certainly make the opening larger. Fortunately, the smaller cutout does do a great job of cooling the intake air (as evidenced by my Car Chip OBD II data) AND not dirtying up the engine bay!
First you need a tested product ( Big Mouth Performance Air Dam ) High quality , increased static cold pressure and it will keep all the debris and water out !
Plus remove the screen, I have studied this type of mesh and I bet you it is 80 % closed so there is no way air can go through. That is why you don't see any results. Do a simple test and remove the mesh and see what happens ?
I like the Big Mouth when it comes to supplying air to the radiator, but cutting the shroud is taking on more risk as well as being more work compared with opening up the front vents
The C5 factory spoiler is spring loaded and is tilted and very low so it will pick up water and road trash and ramp it right into your radiator compartment unlike the BMAD and the results are contamination.
But if think about how the Big Mouth seals off that area water and road trash has no where to go it gets deflected 100 % of the time.
http://forums.corvetteforum.com/show...169&forum_id=1
Regarding the screen: With this setup, having a direct blast of 80 MPH wind is not a good thing, especially if a rock or other hard object hits the filter media at a high rate of speed. Secondly, a hurricane blast of air into the engine bay may keep it ultra-cool, but I wouldn't want to clean up the engine bay every week! The screen I specified slows but also straightens out air flow, while keeping damaging debris out. I think my data logger results clearly show that intake temps are much lower than without the CAI setup. That is a good thing.
Cutting the fog light covers will certainly bring in cold air, but it does get dilluted with super-hot engine bay air. Also, cutting the fog light covers from the outside usually results in a less-than-pretty appearance. This is why many will cover the opening with Z06 screens. This is great if you like that look. I preferred to keep the front end cleaner-looking (IMO).
As far as drawbacks to using the fog light openings, my IAT’s, as displayed by my Tech II, are but a few degrees above ambient when I’m moving and by gluing black plastic mesh to the back of the opening it makes them appear stock unless you really look for them. The only real drawback is the fine layer of dust that lands everywhere in the engine bay from front to back.
Bottom line is all the CAI systems work and most will never hydrolock but some entail considerably more risk than others. If you live in an area where toad floater rains and or clogged drains are a common occurrence then you might want to think twice about using a CAI, especially a bottom breather.
I also use the Big Mouth. The BMAD directs air to the cooling system. Radiator and air cond. The window simply allows the Blackwing a source of ambient air vs engine compt air. It is impossible for the filter to DRAW water through that opening. Water would have to be deep enough to reach the filter.
On other closed systems with outlets through the fog light area, they will draw water due to the fact they are a closed system.
Pavement to bottom of Blackwing 20.00"
How does that compute "but it is more at risk compared to using the fog light openings that are above it ?
Go to products, performance and pick on the Blackwing Icebox for a photo and ordering info.
http://www.c4orcecorvette.com/ for Big Mouth
The simple truth is I your hole in the shroud is in the same location as the ones that suffered hydrolock. Many owners, to their dismay, found that once water gets into the shroud then it is possible to get water into the filter
There is no denying the facts, if water gets into the Big Mouth then it can find its way to your filter. The Big Mouth may offer you some protection but it should be obvious that since the fog light openings are higher off the ground that they offer more protection from standing water then the Big Mouth
The simple truth is your hole in the shroud is in the same location as the ones that suffered hydrolock. Many owners, to their dismay, found that once water gets into the shroud then it is possible to get water into the filter
Its not an issue !
I just don't know what Bill is thinking. I think we have a communication problem. Maybe he's thinking if I drive through 14" of water of water it would force it up there. That may be true but the Big Mouth wouldn't contribute to that. It actually deflects water.
Then a couple of years later when the Vararam came out, people were bashing it for the same reasons. But once some REAL WORLD testimonials came in (fastest intake out there, driving in torrential downpours with no probs, even having pics of driving through a road with water 6" deep), the forum accepted the Vararam.
Now that the Vararam is accepted as being OK, the forum is going back to the intakes that scoop from underneath the front facia!
You guys that have those intakes that have a scoop below your front facia are absolutely crazy!! If your car is lowered you're going to scrape the hell out of that thing, let alone scooping up anything that's right off the surface of the road, AND then a HUGE risk of water injestion. It's too bad that the forum's search feature doesn't work on those old threads about this. I read at least 5 threads where people posted they hydrolocked their motors due to the scoop CAI.
Personally, I went with the Vararam since it is the best intake out there and poses very little risk of hydrolock. But hey, if you guys want to put those intakes on there then go ahead! As long as it's not on my car
Thanks, I had been googling that icebox with no luck
