c5 tranny temps
Have a good one,
Mike
Just wondering.
So, yup, I'd say they can get pretty hot.
And if this is the worst Homer-ism you've had today, it's a pretty good day!
Have a good one,
Mike
seams like 250-260* are the magic numbers of both the oil and trans to back off and cool down.
I was told by my mechanic to add the Transgo kit to the A4. He said it'll cost about $400 for the kit installed. It should give more fluid to the tranny and firm the shift points, resulting in cooler tranny + longer lasting. He also told me, while I'm at it to add a tranny cooler.
I'm not too sure what kinda tranny cooler is the BEST for my car. And while I'm adding a tranny cooler, how about adding an engine oil cooler too.... wouldn't that help, or be nice for the car ... ???
Thanks in advance for your replies... I'm sure a lot of ppl would benefit from some knowlegable ppl on this issue...
If you're going to autocross or road race your car, then you absolutely need a transmission cooler, followed close behind by an engine oil cooler. Probably also a power steering cooler (Z51 cars come with these from the factory, I believe).
As far as the Transgo kit in concerned, I don't see it providing any legitimate cooling at all. And, your mechanic admitted the same thing, when he said "while I'm at it to add a tranny cooler." Shift point firmness is up to you (I'm a clutch guy, myself)
HTH, and have a good one,
Mike
extra headwork to get something to make sense. appreciated
