c5 tranny temps
Thanks,
ralph
You might reconsider completely bypassing the cooler in the radiator. It'll do two things: first, it'll assist cooling the tranny, even with the external cooler you've added. Second, it'll help warm up the fluid on cold days (yeah, I know, you don't see much of those in FL, but you could make a road trip or two).
BTW, remember that the t'stat controls the temperature of the coolant in the engine, not in the radiator. Putting a lower temp t'stat will actually raise the coolant temperature in the radiator. Lowering the point where the fans come on will help in traffic, but that's not where you typically see high tranny temps.
HTH, and have a good one,
Mike
Unless I misinterpreted Mike's post, I believe he's recommending that you do NOT bypass the tranny cooler in the radiator, for the reasons he stated. I had a Hayden cooler installed in mine and also left the radiator tranny cooler hooked up. It works great!
Mike,
I must not understand something here. The engine cooling system is a closed cycle. How will installing a cooler thermostat raise the radiator fluid temperature, while lowering the engine temperature? I realize that a wider open thermostat would increase fluid flow through the radiator, perhaps lowering the amount of cooldown time spent there, however, if the fluid exiting the engine to the radiator is cooler than with the previous thermostat, how could it gain heat while passing through a cooling medium (i.e., radiator)? Thanks!
Ed
Ed
Actually, the only part of the coolant system that is true "closed cycle" (i.e. temperature regulated) is that within the engine. Look at it this way: There are actually two "types" of coolant in the system:
If you think about this for a minute, you can see that the temp differential between the radiator and the engine coolant gets larger as the t'stat's set point (temperature rating) is higher, and vice versa. That's why the radiator coolant temperature will be higher for a t'stat with a lower temperature rating.
Ralph,
You did misunderstand my original post, but you also bring up a very good point about leaks and coolant contamination. It doesn't happen often, but it's
when it does.Have a good one,
Mike
I have noticed my tranny temps up a bit since I put inthe H/C and 160 stat. But I assumed was coinsidental to summer temps.
Generally my tranny temps went from 225 down to 170-195 depending on ambient temps. But it will easlily get over 200 if I drive the car hard in 3rd gear. It also got to near 250 at the track when my oil hit 280 and coolant 235.
I don't think my internal was disconnected (how would I tell). Also not sure if its connected inline with the upper radiator line which I believe is the correct one.
DH
If the external cooler has a line that goes to the radiator, then the "internal" cooler is still plumbed in. If both lines from the external cooler go to the engine, it's bypassed.
Mike
I just can't get my brain to understand your explanation about Rad. & Eng. temps. A vette engine that is running will not have a t'stat that stays closed; it might close for a short period, but will reopen as the running engine's temps continue to climb once the t'stat is shut. There is no scenero where a running vette engine will continue to run without opening the t'stat (assuming normal t'stat ranges).
If the engine generates the heat and the radiator cools it as you say, then the heat in the radiator can not be significantly higher (maybe a few degrees) than the source from where it came (engine). If higher, as you say, what is the source of the higher temps in the radiator since the engine is at a lower temp than the radiator according to your explanation? Sorry, I just can't figure this out how the radiator can have higher temps than the engine.
If the t'stat is wide open, what ever temp. the engine is at will be equal or hotter than the radiator. If not, you have a scenero for an overheating event (boilover) because the radiator will not be performing its cooling function and will feed the engine ever increasing coolant temps until something gives.
The engine will produce a particular number of btu's at a given rpm, biased by load factor (i.e. how much fuel it takes to maintain that rpm). Now, with a high temperature thermostat, more of those btu's must remain in the engine fluid in order to maintain that higher thermostat setpoint. Therefore, a lesser amount of fluid flows from the engine to the radiator. Now, with a lower setpoint thermostat, more btu's must be expelled by the radiator in order to keep the temperature down at the lower thermostat setpoint. Therefore, more fluid must flow through the radiator to dissipate the btu's. That greater flow of fluid, means the AVERAGE temp of the fluid is now higher than before even though the entry level temperature is lower. With the higher temperature thermostat, the entry fluid, though initially warmer, spent more time in the radiator causing the AVERAGE radiator coolant temperature to be lower. However, as the there is continual bypass flow, to say nothing of radiant and convective heat losses from the engine, I suspect the difference in that average temp to be somewhat minimal. Just MHO.
Ed
Ed
AU N EGL (btw, am I right in translating that to "Golden Eagle"?),
Having a lower temp t'stat helps as long as you've got enough airflow through the radiator to keep the engine coolant at the t'stats set point. (IOW, the t'stat is not fully open). I'm not sure what the normal t'stat temperature rating is.
Have a good one,
Mike
I am reletless in keeping my raditor clean. I take a high pressure air hose and blow the crud, dirt, grass and road clagg out before each track weekend. It is amazing how fast chit accumulate in there.
I would think, tranny - tranny cooler (sererate OR not both, ratiator tranny cooler ) --> tranny.
Here is a photo of my set up.
trans cooler left, radiator in back, oil cooler right
the air damn was removed for matainance
