Catch Can on an 04??
Old May 31, 2005 | 10:47 PM
Last C5's Avatar
Last C5
Default Catch Can on an 04??
OK, before I pull the trigger on this let's see if I've got it right. The 04 vert has one tube that comes off the throttle body and runs to the right valve cover - that one is a breather and we don't mess with it. Another tube makes a loop from an outlet in the front of the intake manifold to an outlet about 4" below it in what looks like the front of the valley cover - that's where we insert the catch can. We run a tube from the valley outlet to the top fitting on the catch can and another tube from the manifold outlet to the bottom fitting on the catch can. Right??
All words of experience and wisdom appreciated.
Last C5
Old Jun 1, 2005 | 12:55 AM
Dirty Howie's Avatar
Dirty Howie
Last C5
Are you getting the AMW??
DH
Old Jun 1, 2005 | 01:03 AM
Last C5's Avatar
Last C5
Yes, the AMW is the one I'm planning on using. The hook up is what I'm not as sure of.
Old Jun 1, 2005 | 02:31 AM
hightest's Avatar
hightest
You splice into the same line as the PCV valve.
Insert the one end prior to the PCV into the top of the catch can (inlet), and the outlet (bottom) line routes into the PCV. From the PCV onward it stays the same as factory.
Works well for catching excess oil as well as vapor condensation.
Old Jun 1, 2005 | 11:26 AM
Patches's Avatar
Patches
That is the Z06 PCV setup which, incidentally, I switched my '02 LS1 over to and then added a catch can. The hookup is similar on either setup. The LS1 PCV system looks like this. The PCV valve is highlighted.
Here's a pic of my LS6 valley cover. Note the PCV tube on the front of the passenger side of the cover with the red cap still on it.
I installed my catch can in the right-front of the engine bay on the inside of the frame. You can see the two black hoses in the pic below leading to it.
A shot inside my intake before the catch can.
I get about this much oil from it every 800-1K miles.
Old Jun 1, 2005 | 12:04 PM
vettenuts's Avatar
vettenuts
Just had my TB off the other day and it looks like yours. I am going to get the AMW as well, just curious if you have peeked inside since the addition of the catch can.
Old Jun 1, 2005 | 01:18 PM
Patches's Avatar
Patches
I've had it off since this and very little oil has collected inside since I cleaned it when I first installed the catch can. Most of the oil seems to be coalescing in the catch can.
Old Jun 1, 2005 | 01:32 PM
carnut108's Avatar
carnut108
OK, I give up. What does this mod do?
Old Jun 1, 2005 | 03:44 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I have the AMW Catch Can and it collects about the same amount of oil. Great and relatively inexpensive mod to keep the intake clean.
Old Jun 1, 2005 | 04:31 PM
Dirty Howie
Originally Posted by Patches
I'm sorry but are you sure you didn't mix this up with your urine sample??......
Anyone with FastIntake and LS2 throttle body? What have you done with vent tube from passenger valve cover......
DH
Old Jun 2, 2005 | 12:49 AM
Last C5's Avatar
Last C5
Patches,
Thanks, I read my service manual and all it had was the same picture as your diagram. My 04 LS1 engine has the LS6 manifold and valley cover and I didn't tumble to the difference. Your colored pictures are exactly what I have and now I'm off to get my catch can. Thanks again.
Doug J.
Last C5
Old Jun 2, 2005 | 09:33 AM
Fast one's Avatar
Fast one
I have a Fast intake and LG throttlebody, the valley cover tube is in series with an oil separator, PVC valve and vacuum line. Each valve cover tube vents to the atmosphere thru a fuel filter to keep out dirt. This is a '98 with the newer valley cover and valve covers. Does it make any difference which tube (two valve cover, one valley cover) goes to the PVC/ vacuum?
Old Jun 2, 2005 | 10:00 AM
Dirty Howie
When did you do this.
Is it smog OK
Do you have pics
DH
Old Jun 2, 2005 | 10:10 AM
debmwb's Avatar
debmwb
Patches,
Doug J.
Last C5
I put the catch can mod on my 04 and haven't captured a single drop (the lines are dry too). Don't know why.
Old Jun 2, 2005 | 10:13 AM
Sorny's Avatar
Sorny
I didn't catch anything for about 500 miles, for some reason, when I installed my catch can. I just checked it again last night, and saw about as much oil as what Patches has in his pics. It has been about 1500 miles since install, and there is about an ounce of oil in it now.
Sorny
Old Jun 2, 2005 | 11:02 AM
C5dream's Avatar
C5dream
You can't go wrong with the catch can. I also have the AMW catch can it catches about the same as what Patch's picture shows.
Old Jun 2, 2005 | 11:35 AM
JeremyMSG's Avatar
JeremyMSG
Where can I purchase the AMW, seems that this is the most popular one here
To Catch Can on an 04??
Old Jun 2, 2005 | 11:51 AM
Gray Ghost GS
Here you go: http://www.accmachtech.com/pcvcatchcans.htm
Old Jun 2, 2005 | 12:01 PM
vettenuts's Avatar
vettenuts
Brackets aren't available until next week, and they are out of red and blue.
Old Jun 2, 2005 | 01:11 PM
ivandrea's Avatar
ivandrea
Can someone help me out and tell me if I need/want to do this mod? What are the benifits? I have a H/C car and am going to add nitrous.
