Vibration when turning???????
Old Jun 5, 2005 | 03:59 PM
KODAK's Avatar
KODAK
Default Vibration when turning???????
Not sure what the problem is but when driving my 99 coupe I hear and feel a vibrationwhen I turn to the right. I looked to see if tire was rubbing anything and I don't see anything????? WTF?
Old Jun 5, 2005 | 08:38 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I am having this same vibration problem since getting my car back from shop.
My entire motor, clutch, and rear end were replaced and the front end was checked for alignment after everything was put back together.
Never had this problem before, and I can only feel/hear it when driving around right hand turns at around 20 mph and above.
I'm not sure if this is the same problem you are having, but if it is, maybe somebody will chime in and help us out.
Old Jun 6, 2005 | 12:29 PM
KODAK's Avatar
KODAK
Sounds like the same problem. It drives me crazy! I hope someone will chim in and help.
Old Jun 17, 2005 | 03:10 PM
KODAK's Avatar
KODAK
Anyone?????
Old Jun 17, 2005 | 09:21 PM
T_Vert's Avatar
T_Vert
have long tubes??? I noticed when turning hard right my primary would rub the steering shaft.
Dave
Old Jun 17, 2005 | 10:48 PM
turboc5's Avatar
turboc5
check the wheel berrings. If the vibration you discribe sounds like 4x4 tires it could be wheel berrings, or bad/choppy tires. some times the wheel berrings only make noise when you put a load on them, and they arn't alwise loose when they make noise, hope this helps
Old Jun 17, 2005 | 11:20 PM
ECV-Tony's Avatar
ECV-Tony
To Vibration when turning???????
