Rear end Diff Question
Old Jun 10, 2005 | 10:14 AM
BuzzZo6's Avatar
BuzzZo6
Default Rear end Diff Question
I recently had my 02 six speed rear diff fluid changed. When the fluid was drained the fluid smelled terrible,really bad. The tech at the dealership said the rearend was fried. There has never been a rearend howl and I dont go to the dragstrip and race the car. Could this be true just based on the smell of the diff fluid?
Old Jun 10, 2005 | 10:44 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Not really.. Every time I've ever changed transmission / differential fluid on ANY car, its always smelled pretty bad.
If you don't have any performance issues with the drivetrain, simply thank him for changing the fluids and move on.
Old Jun 10, 2005 | 11:34 AM
Mike Mercury's Avatar
Mike Mercury
it's the Getrag break-in grease. When I bought my new GM 3.42 carrier - it had never been filled with any fluid yet. All it had was the green break-in grease... and it SMELLED
Old Jun 10, 2005 | 11:47 AM
Face's Avatar
Face
Rear end grease is known to smell bad, especially with some miles on it. It it doesn't make any noise, leave it be.
Old Jun 10, 2005 | 01:31 PM
XTrooper's Avatar
XTrooper
Ask this "tech" if he's come across any sweet-smelling rearend grease?
Old Jun 10, 2005 | 03:39 PM
jimcork1's Avatar
jimcork1
Make sure you added the GM posi lube when you changed. If the "tech" was telling you it was fried,, did he add the Posi Lube... If not, you will have chattering from the clutch plates,, then when you go back you could get an I told you so... The "tech" might just not have known to add the extra lube. It should be installed before the new oil is added to fill the differential
So just make sure the posi lube is added as per GM reco's. 99 Nassau Blue
Old Jun 10, 2005 | 03:57 PM
98Z51's Avatar
98Z51
That stuff smells bad even when it's new
Old Jun 10, 2005 | 04:42 PM
slo-vette's Avatar
slo-vette
Good one
If you aren't having problems, leave it alone with the new fluid installed.
Old Jun 10, 2005 | 10:19 PM
kirbyloid's Avatar
kirbyloid
Default diff
Rearend fluid smells very bad out of a new bottle.
Old Jun 10, 2005 | 10:42 PM
C5Jim's Avatar
C5Jim
If it didn't smell bad, then I'd say you had a problem.
I agree with the others, rear end oil inherently smells bad upon removal.
Old Jun 10, 2005 | 11:00 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
Sounds like he consumed too much balogna...cause he was full of it!
Old Jun 11, 2005 | 12:16 AM
SpeedyZ's Avatar
SpeedyZ
Don't laugh, the stuff I took out of mine at 13k had a fruity smell! Well maybe a bad fruity smell. Kind of like if you mixed up some fruit with some gear oil. I never smelt anything like it before. It was a bluish color and looked very clean. I assumed it was factory lube.
Old Jun 12, 2005 | 09:14 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
That smell is normal and doesn't mean there is anything wrong with your diff. The smell is actually the anti-wear additives which are in diff fluid in much much higher levels than they are in tranny fluid or engine oil.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 12, 2005 | 09:33 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Could this be another case of Stealership . I think so.
Old Jun 13, 2005 | 02:55 AM
C54DAZ's Avatar
C54DAZ
Mine smelled so bad my neighbor complained and wondered what the heck it was... All gear oil smells bad and if you get it on any clothes plan on throwin them out cause that stinch isnt going away..
Old Jun 13, 2005 | 07:00 AM
XTrooper's Avatar
XTrooper
Gear oil is one of the secret ingredients used in making Fruity Pebbles cereal!
Old Jun 13, 2005 | 07:12 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
You guys are killing me!!!!
Dave
Old Jun 13, 2005 | 12:41 PM
Dope's Avatar
Dope
Resident moron
Exactly. I once spilled a bunch on myself while working on my car, and got a bunch on my shirt. I ended up tossing the shirt. No matter how many times I washed it with bleach it STILL stank.
No noise, no performance issues? Then keep driving with a smile.
Dope
To Rear end Diff Question
