Continuous Pull Key, Wait 10 Seconds
Old Jun 11, 2005 | 01:37 PM
huskerhoss's Avatar
huskerhoss
Default Continuous Pull Key, Wait 10 Seconds
I am getting the error message "Pull Key, Wait 10 Seconds" everytime I start and restart my 2000 C5. The vehicle runs fine at an idle but will not move over 1 mile an hour and then dies. I have cleaned both of my keys, disconnected and reconnected the battery and pulled out and replaced fuses 23, 25, and 27. I've also gotten new error codes 99 HVAC U1160 HC, 60 IPC u1160 HC and AO LDCM No Comm. I have a new battery in the vehicle and the column lock bypass replaced. Very frustrating, thanks in advance for any help to at least get it to run so I can drive it to a dealership without paying for towing charges.
Old Jun 11, 2005 | 03:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like your ignition cylinder may be causing the problem. Try this. Spray some electrical contact cleaner into the ignition cylinder lock and then insert the key and pull it in and out a few times. The sensing contacts inside the cylinder may just be dirty.
As for the other codes, if you clear them and start the car, do they come right back?? Normaly the U codes indicate one or more modules are getting low voltage or are not communicating with the other modules. All of your codes indicate that the Door control modules are causing the issue. Check the connections that connect the Door control modules and the door to the car and make sure that they are tight, clean and dry. The connections are inside the accordian tube that connect to door to the body.
BC
Old Jun 12, 2005 | 01:08 AM
Hellobkk's Avatar
Hellobkk
Had same problem,culprit was croated relay under passenger floorboard.
Old Jun 12, 2005 | 01:14 AM
FRCTony's Avatar
FRCTony
Can you give a little more detail. I've got the same issue. I can hear clicking from the passenger floor area, but I thought that was just normal since I have the toe board/access cover off.
Was the relay corroded inside, or just the connector? How did you fix it?
Thanks!
Old Jun 12, 2005 | 08:27 AM
huskerhoss's Avatar
huskerhoss
That makes complete sence because my air conditioner condeser hose was blocked and backing in to the passenger side floor board. How did you fix this?
Old Jun 12, 2005 | 10:38 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My BCM was wetted and I started to have some weird problems. My BCM circuit board had corossion on the back of the board. I cleaned it off but it still had an issue. Had to get a new one.
Here is a picture of the old board:
The white corrosion that I found on the board was on the pins at the bottom of the board near the connectors.
I removed the board from the aluminum box, used a stiff nylon brush and alcohol to clean the board. If you remove the board from the box, be careful. The board is ESD sensitive!! Make sure that you examine the IC component at the top of the board. Check the position of the heat sink. See if your heat sink touches the case or not prior to removing the board from the case.
If there is corossion, just clean it off and reinstall the board back in the case. DISCONNECT the battery prior to removing the BCM from the car!!! It is powerd all of the time!
BC
Old Jun 12, 2005 | 11:33 AM
huskerhoss's Avatar
huskerhoss
I've got mine out but there looks like there is quite a bit of corrosion throughout the whole board. I will try and clean it and see what happenes but worst case, how much does the BCM cost. Do I need to order it or will a dealership have it?
Old Jun 12, 2005 | 12:17 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Ka-ching.......$ They are not cheap. I have found that ordering from Fichtners in MT, or Fred Beans is the best price. I have saved hundreds just on two items alone, that I ordered from Fichtners. Others may chime in. They need to be set up by a stealership after you install it...I think. Anyone?
Old Jun 12, 2005 | 12:40 PM
huskerhoss's Avatar
huskerhoss
Mission accomplished. I took a toothbrush with rubbing alcohol to all of the corroded areas and then a blow dryer to thoroughly dry the piece off and it worked like a charm. All of my electrical demons that I have been fighting for two months instantly went away. I cannot thank everyone enough on this board. Thank you so so much, I cannot imagine what this board saved me in mechanical expsenses.
Old Jun 12, 2005 | 01:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Congrats!!! Well done!! You can contribute to all of out C6 Z06 purchase fund drive!
Was the heat sync touching the metal case or not??
BC
Old Jun 12, 2005 | 01:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You fixed the symptoms! Now you need to eliminate the cause. The HVAC box drain and the Fan motor vent hose is allowing condensation to enter the passengers foot well. Insulate the black vent hose with bubble wrap and cut the end of the drain hose off!!
The flash light beam is shining on the rubber elbow connection area.
Fan motor drain hose:
Let me know if you need more info. I would remove the passengers carpet and make sure that it is dry!
Bill
Old Jun 12, 2005 | 05:24 PM
huskerhoss's Avatar
huskerhoss
Bill,
I had fixed the condensation hose last weekend, I had about a full 12 oz can of water drip on to my arm so hopefully that was the culprit. I just popped the modle out of the tin box and replaced it as it was before. I did not notice the heat sensor you had mentioned. I am not very mechanically inclined so I think I just got lucky today. Or could I have messed something up? Thank you again for your help.
Jeff
To Continuous Pull Key, Wait 10 Seconds
