Electronic Climate Control Display FIX
Old Jun 12, 2005 | 01:07 PM
DirtyGlass's Avatar
DirtyGlass
Default Electronic Climate Control Display FIX
From time to time my display would go dark, dim or not come on at all. I think there are other members that are shelling out BIG bucks for a replacement. Well I just fixed mine in about an hour. The hardest part was removing the console plastic. What a pain in the A$$....
The problem is cold solder joints on the circut board, not the display like some assume. It is rare but the displays do go bad but in most cases hitting the resistors on the display circut board fixes the issue. Not being an electronic genius i decided to just tap each resistor, both sides of the resistor, with a hot 15W pointed tip iron.
I had the same problem with a Jeep Grand Cherokee limited radio display and found the fix on the web. I just applied the same technique and senario to the Climate Control, and Viola.....
Good luck, hope this helps and happy fixing For a reasonable charge of 25 bucks plus shipping I can fix and test the faint hearted....
Old Jun 12, 2005 | 01:17 PM
Scubanme's Avatar
Scubanme
I am having a problem with my display as being extremely faint. The display glass inside the unit with the digital numbers seems to be burnt looking on one corner, did yours appear that way?
Old Jun 12, 2005 | 01:18 PM
DirtyGlass's Avatar
DirtyGlass
That seems to be normal, my Cherokee looked real burnt in one corner, but it proved to be fine. Sounds like you have the same problem as I had.
Old Jun 12, 2005 | 05:51 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Well mine just went dead altogether. I already soldered my seat pc boards so I guess its time to experiment with the CC. Thanks for the info.
Old Jun 12, 2005 | 09:09 PM
ericdwong's Avatar
ericdwong
Good info. Mine is always dim, so in the sunlight I can't read it.
Old Jun 13, 2005 | 01:24 AM
98Z51's Avatar
98Z51
I had the same issues with mine, after a few minutes fixing some cold solder joints it was working like new.
Old Jul 7, 2005 | 02:33 AM
Scubanme's Avatar
Scubanme
What the heck is a cold solder joint? I know only know of hot soldering irons?
Old Jul 7, 2005 | 01:55 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
What, you’re a welder by trade, aren't you?
Basically it's a solder joint were the solder was not completely melted, thus giving it a "dull" surface / lack of "penetration" of the surrounding metal components, whereas a good joint is nice and shiny.
http://forums.corvetteforum.com/show...196&forum_id=1
Old Jul 7, 2005 | 01:59 PM
2000BSME's Avatar
2000BSME
I sent mine to a guy in Boston, and he did the fix for $40. He gave a 1 year warranty on the work too. He does these all the time, and it's my impression that he actually replaces the VFD and the LED's. Works great now.
Old Jul 7, 2005 | 03:01 PM
Dan_the_C5_Man
Again, my research indicated it's not the display components.. And that makes sense. I doubt he's installing new displays (that are vendor specific, i.e. must be sourced from GM or GM's suppliers) for 40 bucks. More likely he's refreshing the soldering joints as stated above, or replacing a component or two (probably less than 5 bucks in parts) in the AC power supply section.
Old Jul 10, 2005 | 10:23 AM
dugsc5's Avatar
dugsc5
Default CC panel
i''m having the same problem with the lights i cant see them anymore. just how hard is it to remove the panel???
Old Jul 10, 2005 | 11:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If anybody has a defective one, I will attempt a repair. Never done one before buy I will give it a try and all it will cost you is the price of shipping!
BC
Old Jul 10, 2005 | 12:01 PM
chuckster's Avatar
chuckster
In fact cold solder joints are a major cause of lots of circuit board failures.. With ALL my electronics... If there is any flaky behavior.. I re-flow all the points.. Kinda fun.. Especially when it wakes up a dead item..
I just fixed a BRAND NEW back massager.. worked for one day then cut out intermittantly.. Then stopped..
too much hassle to return.. I just opened it up and started hitting every joint with the soldering iron.. Bam... Fixed!
Old Jul 10, 2005 | 05:44 PM
ericdwong's Avatar
ericdwong
TTT... OK I need help on this one, Im pretty electronics and circuit board saavy but which part has a tendency to have the cold solder joint? I poked around today on both sides if the display itself's contacts as well as some of the resisters on the "back board". No luck, my display is dim still and the fan indicator is 1/2 dead. Help!
Old Jul 15, 2005 | 10:23 AM
Crispyc21's Avatar
Crispyc21
TTT, my display will delay coming on after I start my car. Sometimes it will not come of for 30 sec. sometimes it will take a couple minutes before it comes on.
Any pictures of what to look for?
Old Jul 15, 2005 | 01:06 PM
jdmvette's Avatar
jdmvette
Night Owl for life
TTT too. my up and down blower speed buttons do not light up. What do I need to do to fix it? Thanks.
Old Jul 15, 2005 | 03:32 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
the burnt look in one corner is a product of how the vaccume tube display is made. it's normal, they all look that way.
To Electronic Climate Control Display FIX
Old Jul 15, 2005 | 10:42 PM
probaja's Avatar
probaja
Can somebody post a pic of the exact solder joints they are hitting to correct this issue. I thought I hit them all but im still having the 'dim' issue..
Old Jul 16, 2005 | 11:10 AM
ericdwong's Avatar
ericdwong
Me too, I just sent mine to the ebay fix it guy...
Old Jul 16, 2005 | 01:43 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Website, link?
