M6 Shift Knob Removal
Old Jun 12, 2005 | 08:55 PM
msnyder_1979's Avatar
msnyder_1979
Default M6 Shift **** Removal
I appologize if this has been asked before, but I was unable to find it in a search. How in the world does the stock shift **** come off?
Old Jun 12, 2005 | 08:59 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Pry the cap off (where the shift pattern is), and then pull the rectangular pin out with a pair of vise grips (it could be REALLY tight) then unscrew the ****. Simple as that.
Old Jun 12, 2005 | 09:07 PM
ronniej's Avatar
ronniej
St. Jude Donor '06
This is a quote from the Ripper install under the Tech Tips:
1. Remove Shift ****: Pry up the plastic shift pattern on the tip of the shift ****. Remove the aluminum pressure pin using a flat head screw driver and a vise-grip. Fasten the vise grip to the pin and insert screw driver under tab and pry up. Note: If pin won’t move use some spray lube or liquid wrench to loosen up. Unscrew the shift ****.
Old Jun 12, 2005 | 09:19 PM
MY1STPEWTER's Avatar
MY1STPEWTER
When I shortened my shifter that was my main worry was getting the demon key out of the ****. I got a pair of needlenose vise grips and attached them to the demon key and then got the biggest screwdriver that fit thru the mouth of the vise grips. I then took a hammer and started tapping the screwdriver until it came out. It really came out a lot easier than I thought. Once it's out just unscrew the ****.
Old Jun 12, 2005 | 09:23 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Try this. It worked for me.
http://www.conceptualpolymer.com/corvette_install.htm
Old Jun 12, 2005 | 11:40 PM
rickko's Avatar
rickko
Once its removed you can take a dremel to its sides and file them down so it isn't so friggin' tight! It only serves one function, to keep the **** from spinning so, making it easier to remove in the future is a good thing.
I also did one other tiny mod to the key before replacing it. I cut into deeper where you insert the screwdriver so there is more lip for the screwdriver to contact when prying it upward.
..rickko..
Old Jun 12, 2005 | 11:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to remove the demond key!!!
Once the key is removed the **** will unscrew.
BC
Old Jun 13, 2005 | 12:35 AM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
I use two flat head screw drivers and it pries right out. I can have the shifter off in under 30 seconds.
To M6 Shift Knob Removal
