Thanks Gary and good morning. I had to remove the big mouth. It was fine at the track but in every day driving it was causing surging issues. Now I have to go slam you in the next post.
You know I am disappointed by this news. I really liked the design on the big mouth. Bob can you email me and tell me more about what happened with the big mouth? Is it something that is just a annoyance or do you think it hinders the operation of the engine? What do you think of that hood by the way. It is the best looking aftermarket hood I have seen, I love it when it is painted in a two tone fashion.
I am feeling post prolific today. Well I might as well expose myself early to the dreaded corvette forum ram air flame crew. I am convinced after owning two vararam equipped C5s, and after reading many posts on the subject that there are three reasons the vararam out performs other CAI designs. To me the question of whether or not it does in fact out perform the competition has been sufficiently proven. I will list these in the order of most importance in a drag strip situation, 1/4 or 1/8 mile run.
1. It needs no forward movement of the vehicle to receive ambient or cold air. The vehicle starts the race receiving ambient air.
2. Vararam filter is very high flow design.
3. The sealed design and location of the intakes on the front of the vehicle in the airstream creates high pressure on the outside of the air filter. I believe this creates a situation in which there is less parasitic HP loss in the engine. Is this ram air effect, well not really but it has become the popular term for this sort of set up.
Actually Bob you not only called me dumb you said it was the dumbest statement. Which imply's I have made other dumb posts. Oh well I guess you are right there but lets keep that between buds. I think you may be thinking about the dreaded day I replied to a thermostat question.
So I suppose your engines' compression ratio of 10:1, or whatever it is, only applies when you are flying your corvette at supersonic speeds?
disconnect your ignition system and turnover the engine with a pressure gage attached to a spark plug hole. You will find compression. You love to make comments to everyone on this board about how "that's the dumbest thing I've heard anyone in tarnation say on this blasted....blah blah blah"
Stop attacking people and stop making absolute statements like "air is this... air is that... this can't happen."
You sound like the typical "know it all".
Why don't you try reading before running your mouth? We are discussing air going into the engine, not after. Hello, anybody home?
Hey Gary, obviously 2000BSME doesn't know that occasionally friends bust their buddies *****. No, I wasn't referring to the thermostat deal. I had forgotten all about that. Thanks for the reminder.
I have given you Vararam guys tons of info that you choose to ignore. You want it, run it. Don't forget my challenge. Run instead with panty hose and you'll see the same gain.
Hood looked good.
The surging is caused by the cutout in the shroud. I have enclosed the Blackwing and it's OK now. It was drawing ambient air and also engine air whuich caused the PCM to constantly adjust fuel trim. Problem solved.
Reason I removed big mouth is that it was tested by Team ZR-1 and shows no gain at the PCM. I am going to test for consistancy and ET's without it.
Sounds good to me! I know Korreck will rip me a new one for this but I was also thinking......
What about the fact.... well lemme remove that word and say the possibility.. What about the possibility that the vararam also takes a FRONTAL part of the car and makes it an intake opening, thereby reducing the frontal area and having less drag? Ever cup your hand and stick it out the window at 60 MPH? The difference in wind resistance between your hand horizontal and vertical is astounding. Those "cups" in the front of our cars are rather large.....
Again, I'm not saying that vararam equipped Vettes defy physics or even drop .001 cd, just saying that the POSSIBILITY of less resistance + "ram air" + "cold air" + high flowing albeit crappy filter could equal a more efficient air intake.
But I'd take being a better driver anyday..........
But you're not reducing the frontal area. Think about this: It's great to think that the forward velocity of a car is being converted into a free supercharger. The actual air pressure gain is extremely small at automotive speeds. For example, at 150 mph, the pressure gain when air is efficiently brought to rest is 2.75 percent. Because this is a dynamic effect, it is proportional to the square of the air velocity. At a more realizable automotive speed of 75 mph, the effect (again with 100 percent efficient conversion of velocity into pressure) will be only one-quarter as great — that is, just under seven-tenths of one percent. In fact, velocity energy is not converted into pressure at 100 percent efficiency. A figure of 75 percent efficiency is usual, which reduces our notional ram-air gain at 75 mph to one-half of one percent.
Even if you were able to reduce the frontal area, the front end is designed to better give a C/D, to help get better gas mileage and lessen front end lift so the air is not smashing into the front end but above and around it. Look at a hood you see dust on it that just sits on top which shows the airflow is being driven above it
I hope you don't feel ripped. I don't know how else to explain it.
Dust shows nothing other than the fact that we live in a dusty world. Dust is on every single square inch of my car, inside, outside, in the engine bay, and everywhere else. I rarely clean this dust off, so that I am constantly reminded, that we do indeed, live in a dusty world.
No, I doubt anyone feels ripped off, but they may feel like you are talking to a point that is purely your own fantasy of the events, as you would wish them to occur-given the fact that you own an inferior air intake product/system and refuse to upgrade to the best one made to date for our cars.
You asked for facts, I presented facts. If my calculations are wrong, show me the errors. It would appear that you either don't understand or choose to ignore them. That makes it difficult to carry on an intelligent conversation.
You have also ignored my offer to bury the hatchet. I offered.
Perhaps you can explain your statement a few weeks ago that adding a cutout for the Vararam reduces frontal area.
I also requested any of you running a Vararam to remove it from the MAF and make a timed run with panty hose covering same. I have stated you'll have the same ET gains. To date no one has done this.
You folks running the Vararam can offer no facts as to how it works. I have posted fact after fact on why it won't. Show me !!!!!!!!
So bob, why did you cut the shroud?????
Korreck= the joke of the board.
Be advised that for what ever reason Mr. New Vetter doesn’t like me. A few months ago I sent Mr. New Vetter a PM and asked if we couldn’t get along. Mr. New Vetter declined so I now ignore him and his comments. It appears to bother him greatly as he is always taking jabs at every opportunity. Poor baby.
When you say "on the track", are you talking drag strip or track?
Drag strip.
This is definitely not true if you have a Z06 or hole-drilled cover. Much more cold air enters the engine bay and is deflected upward, whereas the openings at the bottom of the engine bay don't help much in getting rid of the hot air that rises to the hood.
After installing my cold air mod, components in the engine bay are definitely cooler to the touch after a long run. Try touching stuff in a VR-equipped C5 after a long run - but have a burn kit handy!
What if you don't have a Z06 or hole drilled cover?
