Oh well, check the boob tube. It finally quit raining here. We have a big race next Sat. Corvette Challenge and also a run for another Wally in the regular event. Challenge will be 1/4 mile and regular event will be 1/8. They rotate between 1/8 and 1/4 for the reg events.
Gotta remember which is which so we don't shut down to early.
But even if there is a miniscule difference, the drivability issues you describe (surging) would have to be taken into account.
And again, I tend to believe that the surging is the result of that hole in in your radiator shroud.
If the search function were up you would be able to find lots of information and many examples of this surging problem using the Blackwing and a cut radiator shroud.
The only surprising thing is that you did not have this problem before now.
Cutting a hole in the shroud and NOT adding a wire mesh screen is somewhat akin to removing your MAF screen and expecting your engine to not notice the difference. My engine doesn't surge and I do not have an enclosed box over the filter. I also helped install the mod in a friend's C5 and he has had no surging issues. The key is the screen - it straightens air flow and prevents large debris from annihilating the filter.
Dave, you did a great job and you did it your way. I've done mine my way, and for a reason. I drag race. Don't need a screen, don't want a screen. What diagnostic software do you use? Last question. What would cause the air to swirl? Thanks.
I guess I assumed that you have a scoop installed to channel air up at the opening. Without a scoop, heat from the radiator may find its way into the opening - another reason why I wanted a scoop - to insulate the incoming air from the radiator heat. If I did have any surging issues, I would've had my car tuned and I have no doubt that this would optimize power output - maybe someday.
From what I've read here in this forum, turbulent, unregulated air into the MAF causes what the computer sees as an excessively lean (uncorrectable) condition and the result is almost always some lean code-throwing. This is why 2002+ Z06 owners experience lean code displays after they install a Warhead or Blackwing intake filter. I believe what you experienced is related to air velocity into the filter. By encasing the filter, you have created a high-pressure area around it, slowing air flow into the filter.
Here's some info for you. I talked to a tuner and he told me exactly how it was acting and how to fix it. Surging is caused by the following: While stepping on the gas pedal the air gets pulled in and the PCM adjusts as its now richer but then when lifting on gas pedal or low RPMs the hotter engine bay air also gets pulled in and forces PCM to adjust again.
It also depends on how PCM is tuned and fuel trims not being close to perfect. Your PCM is forced to surge back and forth with colder/hotter airstreams.
I have now prevented the engine bay air from getting into the filter via the cover and the surging has gone.
I don't think the screens have anything to do with it. I think it's just the way your PCM was tuned.
Remember that the screen does slow the flow of air onto the filter. I would think that this would temper the hot/cold scenarios you mentioned. Remember too, that a stock Z06 with open fascia must experience varying levels of hot/cold, depending upon vehicle speed. However, the sheer volume of air in the engine bay may tone down temp changes as well. I do know that according to my Car Chip data, intake temps in my C5 are normally consistent (close to ambient) unless heavy stop& go driving is ecountered. Another example I just recalled is the K&N intake system - no cover for its filter and no surging (at least of which I've heard). Instead of a screen, this system limits the shroud opening (and cold air), so that may also temper the air temp fluctuations.
You told me you had a 195 thermostat. How do you get the temp below that ? Looks like you should get that gauge checked.
How are you getting ambient air to your filter?
I think you know this was a non scientific study that was based upon strong bias by both these gentleman. That being said, a non rocket scientist would agree that K&N is a performance improvement over stock due to better air flow which will affect the filtering capacity. This all boils down to what you are looking for in performace versus filtration. I think for you it really boils down to your unreasonable dislike of one product.......Vararam.
I'll tell ya Dave, I'm getting EASE diagnostic software and LS1 Edit. At least then I'll know exactly what's going on and why.
I wouldn't think the screen would slow the airflow and I don't see how the opening in the shroud would cause the air to swirl. Key words are 'I wouldn't think', but I sure don't know.
All I can tell you is that the tuner I talked to descibed exactly the way my car was surging and how to fix it. I did as he suggested, which I was going to do anyway, and you know the rest of the story. Fixed.
He also suggested HP Tuner but I am going with EASE and LS!. I think that for guys like us that like to do our own things rather than just purchase supposedly go fast goodies, this software is a requirement.
You been following me around like a little puppy dog. Next weekend will be the last in Fl for awhile. You going to be at Bradenton next Sat? Or do you have another lame azz excuse. I just want to be able to flip you the bird one last time this summer
I don't think you have to give up filtration for performance. Just have to find a better way to do it.
You're right about the Vararam. They talk about their ram air effect. All they're doing is ramming it up their cutomers azz,
WORK, you know that thing us POOR folks do. E-mail it to me. My son bought me a really nice Nikon camera for fathers day, who knows I may be sending you a pic.
I agree that the tuning software would be great to have. How much is it setting you back? Does the manual do a good job of taking you through the proper way to make adjustments?
Definitely look at HP Tuners or EFI Live. Integrated scanning, logging and tuning rock. Your tuner suggested HP Tuners with good reason.
With whats out there now, I wouldn't even consider LS1 edit. Either Version 7 of HP Tuners, or EFI live are the way to go. HP Tuners is not VIN specific but year specific. If you have other GM cars you can tune them too as long as they are one of any two year models you select. Any GM cars in those two years. EFI Live has free upgrades.
Dave, I also belong to Team ZR-1. We get a discount and special tools with EASE. Not sure of the price because they are in the middle of testing and not ready to release. LS1 is around $450.
EB20003 has also posted good info. I need to check it out later. Another tuner I know did recommend HP Tuner.
