Anyone know what these DIC Codes mean?
Old Jun 14, 2005 | 04:43 PM
Nassauvette's Avatar
Nassauvette
St. Jude Donor '12
Default Anyone know what these DIC Codes mean?
This past weekend I attended a corvette show. Upon returning from an hour and a half road tour in 95 degree hot and humid weather, after accelerating from a stop, my check engine light came on and I got a DIC msg of "reduced engine power". In addition I got the "check traction control" msg at the same time. Car ran like crap, definately the reduced power safety mechanism had kicked in. Luckly we had arrived back to the resort the show was being held at and I was able to get the car to the parking lot and shut it off. I let everything cool down for 30 minutes, started it back up and everything ran fine. No DIC msgs., check engine light was off. The next day I drove 2.5 hours home, no problems. So last night I finally had a chance to check the codes and here is what I got:
10-PCM
P1518H (PCM to TAC Module Serial Data Circuit)
28-TCS
C1278H (TCS Temporarily Inhibited by PCM)
Both being "history" codes. My confusion is what exactly PCM (Powertrain Control Module) to TAC Module Serial Data Circuit means. It sounds like when the P1518 code tripped for the PCM, it triggered the code for the Traction Control System so then I got the C1278 code. Any ideas? I am also assuming that since both are history codes, is seems as though everything is functioning properly now and to just keep an eye on it to see if it happens again in the future.
Old Jun 14, 2005 | 07:26 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
TTT for you.
Old Jun 14, 2005 | 08:41 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
here is the info for
P1518
File Type: doc
Old Jun 14, 2005 | 08:42 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
here is the info c1278
File Type: doc
Old Jun 14, 2005 | 09:11 PM
Nassauvette
St. Jude Donor '12
Wow, thanks NOT-MEE, great information, very much appreciated. Now I just need to determine if I should take it to the dealer, or just keep an eye on it since everything seems to running normal now.
Old Jun 14, 2005 | 09:18 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
anytime
Old Jun 14, 2005 | 09:39 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
They are history codes I would reset the codes and see what happens.
Old Jun 14, 2005 | 09:54 PM
Nassauvette
St. Jude Donor '12
That is what I was thinking. I figured since they are history codes and it has run ok since, no new DIC msgs, I'd keep an eye on it to see if it happens again before I bring it to the dealer. Thanks again for the excellent information and advise!
To Anyone know what these DIC Codes mean?
