billman2
Old Jun 16, 2005 | 09:33 PM
billman2's Avatar
billman2
3rd Gear
Default billman2
Hey, Hey. my 99 has no back-up lights. Both bulbs look good. Is there a sensor, switch in / under the shifter plate or is it located in the rear w/ the tranny (6 spd)????
Old Jun 16, 2005 | 09:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yes there is a switch
Old Jun 16, 2005 | 09:57 PM
purrvert's Avatar
purrvert
There is a switch for the backup lights on the right hand side of the transmission for an MN6, also the 1st-4th lockout solenoid. Mini fuse #21 and it all ends up in ground 401. The trans switch is wired with grey and brown wires on a 2000. Do your approach lights work? They operate from mini fuse #2 and micro relay #38 also use ground 401.
To billman2
