Rotors
Old Jun 19, 2005 | 12:09 PM
FLL-Mike's Avatar
FLL-Mike
Default Rotors
I wanted to upgrade to cross drilled and slotted rotors. Each company puts their own spin on how they are to be drilled. Some say there should only be a maximum of 20 holes on the front and 18 on the rear. Other have 30 +. Is there any set standard that work well without having to purchase them from say the Baer line?? Also I heard that GM make the cross drilled rotors. Are they any good? Are they plated to avoid rust?
Also FYI...I checked on Brembo rotors from a brake company in MASS. Was told that Brembo doesn't even make domestic rotors but sells their name for packaging purposes.
Thanks....
Old Jun 19, 2005 | 12:27 PM
vettenuts's Avatar
vettenuts
I looked into this a couple of years ago. Several folks here on the forum had complained about the Baers cracking, even without track use. I ended up going with the Wilwoods because everyone I contacted had not had this problem with them. You will need to assemble the two piece fronts and twist wire the fasteners though, so be aware of that if you decide on the Wilwoods.
Old Jun 19, 2005 | 12:35 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
wilwoods are great, but they are very expensive. I have the baers and they are expensive as well. If you want cross drilled/slotted stay away from the gm rotors. they are not zinc coated and will rust as soon as they get wet. a popular option are sportbrakes. they are $250 shipped if you mention you are a forum member. www.sportbrakes.com. they also have a store on ebay
Old Jun 19, 2005 | 12:39 PM
SGT. PYLE's Avatar
SGT. PYLE
All Brembo rotors along with Napa's and most other after market rotors and made by PBR in Canada and the US. Brembo just buy's their blanks and does the machineing and zinc washing and sells them in their pretty boxes with their name all over it. I have a set of Brembo D&S zinc washed rotors that have been on my ZO6 for about 3 months now that need to be painted. No rust but they look like crap, not shiny and metallic, more a dull hardwater stain look. As far as your question, I dont know. It is best to have no holes at all but I just like the look. I have not really noticed any increased brakeing performance from D&S rotors, just a sportier look.
Old Jun 21, 2005 | 08:12 AM
FLL-Mike's Avatar
FLL-Mike
Do you have the Z06 Calipers???
Old Jun 21, 2005 | 08:09 PM
toplessvettetherapy's Avatar
toplessvettetherapy
I agree with SGT.PYLE I have a set on my 98' vert and have read alot of articles on them and think they look really but are other wise a money trap.
Old Jun 21, 2005 | 09:50 PM
95BLKVette's Avatar
95BLKVette
What about Raybestos Brute Force?
Old Jun 22, 2005 | 11:43 AM
vetteamerica's Avatar
vetteamerica
The GM D&S rotors are the best bang for the buck!!
Yes they are not zinc coated but they are dirt cheap compared to the BIG name brand (waste of money) rotors.
I simply bought a $20.00 caliper paint kit and painted all the rotor hubs black so rust is a non issue now.
Total cost:
4 GM D&S rotors $200.00 s/h included Ebay
1 black caliper paint kit $20.00
Old Jun 22, 2005 | 06:03 PM
csexton's Avatar
csexton
Take a look at sportbrake. Zinc washed and they come in different configurations.
Old Jun 22, 2005 | 06:12 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
just made my order w/ sportbrakes.. i had them on my C4 and loved them..
To Rotors
