Hesitation/Flashing check engine light
Old Jun 21, 2005 | 10:47 PM
Dicecal's Avatar
Dicecal
Default Hesitation/Flashing check engine light
I have a 2001 Coupe with 30K miles. Recently I have been getting some hesitation, and sometimes accompinaied with a flashing check engine light. Any ideas? Would I need to do a de carb procedure with only 30K miles. The gas in AZ is pretty bad. Any suggestions? Thanks in advance.
Old Jun 21, 2005 | 11:14 PM
VetteDrmr's Avatar
VetteDrmr
You've most likely got a consistent misfire (the flashing Check Engine Light) on one or more cylinders. Check over your plug wires, etc.; I bet you'll find one that's loose.
HTH, and have a good one,
Mike
Old Jun 21, 2005 | 11:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When the flashing occurs, check the DTC codes in the DIC. Here is how you do it:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
Most likley you will find that you are getting a PCM 0300 code = cylinder misfire.
Check your plug wires and plugs as stated above!
Please let us know what you find.
Bill Curlee
To Hesitation/Flashing check engine light
