Disappointed with lowered C5 :(
Old Jun 28, 2005 | 06:26 PM
Prosecutor's Avatar
Prosecutor
Default Disappointed with lowered C5 :(
Well, I lowered the Vette last weekend. Nothing drastic, I just turned the front screws 4 times and the back screws 5 times. I didn't cut the bushings. This resulted in the modest drop that I expected. The car looks great....unfortunately
IT RIDES LIKE IT IS SUPPORTED BY FOUR LIMP D*CKS!
Seriously, I'm not even sure I have shocks anymore. I had to travel to a mediation today and spent 7 hours driving. It felt like someone was kicking me in the *** on some of the roads (hwy 74 in NC - Charlotte to Asheville for example).
Most of the posts I've seen note minimal to no change in ride quality with modest lowering. Any thoughts? Anyone experience the same thing?
I may need to ditch the stock shocks and go with something else, or raise the car back up. Will it return completely to normal if I turn the screws back? Thanks in advance.
Old Jun 28, 2005 | 06:43 PM
elric's Avatar
elric
I'm running the Z51 suspension with the stock bolts and it rides a little rougher but still pretty smooth.
I can remember how many turns I did, but I think it was max on the front and pretty far on the rears.
Probably have 12k or so miles on them since I lowered it and I would never put it back the way it was stock.
I am on runflats still, but I hear if you change out those, it makes the ride a bit smoother also.
Old Jun 28, 2005 | 06:49 PM
blackbelt's Avatar
blackbelt
What kind of suspension do you have? How many Miles? It gonna ride a little stiffer but shouldn't be that bad.
Old Jun 28, 2005 | 06:50 PM
Prosecutor's Avatar
Prosecutor
2003 Coupe, stock suspension...41K miles. Thoughts?
Old Jun 28, 2005 | 07:00 PM
AU N EGL's Avatar
AU N EGL
When you lower your car you loose suppension travel and ride quality will suffer. Also a new alignment is needed when lowering your car.
Good Luck
Old Jun 28, 2005 | 07:18 PM
RoHo's Avatar
RoHo
41,000 miles, You need new Z06 type shocks, you won't beleive the difference in the ride
Old Jun 28, 2005 | 07:26 PM
Old Rotor Head's Avatar
Old Rotor Head
I agree but don't get hung up on the Z06 shocks, check around.
Old Jun 28, 2005 | 07:27 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
Z06 shocks, if that doesn't work, consider selling it
Old Jun 28, 2005 | 07:38 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
when you lower the car, you cut down on the suspension travel. Either you bottom out and look good or you raise it back up and get some movement out of the suspension again.
ching.. ching...
VR
Old Jun 28, 2005 | 08:29 PM
viperZ06's Avatar
viperZ06
My pappy always said, "If it ain't broke, don't fix it!"
Old Jun 28, 2005 | 08:32 PM
yellow01's Avatar
yellow01
What Tom and VR said is spot on (They don't need me to tell them that though ).
You decrease your travel but your spring rate stays the same. Your shocks are now constantly compressed slightly, and the springs still only offer the same resistance to movement.
Z06 shocks would be a waste IMHO unless you get them used. For slightly more I would get Bilstein sports which are designed for a slightly lower vehicle. I have them and like them.
However, the spring issue remains. With the base FE1 spring, which I can tell you is VERY soft, you are simply going to require more travel/clearance.
Now, some springs and shocks and you'll be a handling monster...but the ride will change.
Old Jun 28, 2005 | 08:35 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Damn. Quit beating around the bush. Tell us how you really feel about the ride now that its lowered
Seriously, this is one of the big reasons why I won't lower mine. That and clearance/handling issues.
Old Jun 28, 2005 | 08:36 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I'm surprised that you felt any difference at all. Mine is lowered like that and I can't tell any difference (25,000 miles on mine).
Old Jun 28, 2005 | 08:52 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Not only that, but it looks juvenile!
ju·ve·nile ( P ) Pronunciation Key (jv-nl, -nl)
adj.
Not fully grown or developed; young.
Of, relating to, characteristic of, intended for, or appropriate for children or young people: juvenile fashions.
Marked by immaturity; childish: juvenile behavior. See Synonyms at young.
n.
A young person; a child.
A young animal that has not reached sexual maturity.
An actor who plays roles of children or young persons.
A children's book.
Old Jun 28, 2005 | 08:59 PM
ZfidyONE-84's Avatar
ZfidyONE-84
your pappy was a smart man
i had a 91 accord i decided to lower, and i kicked myself for doing, but at the time i was young and dumb
Old Jun 28, 2005 | 09:13 PM
Snake11eyeS's Avatar
Snake11eyeS
Mine is an 04 with 800 miles and I didn't notice any difference after lowering.
Old Jun 28, 2005 | 09:27 PM
Prosecutor's Avatar
Prosecutor
adj.
n.
A children's book.
You think so huh? The drop is so slight that I (and most anyone else) can barely tell the difference when parked next to my co-worker's stock Coupe. It barely shortens the gap above the tires.
Maybe I should just drive around sucking my thumb and sh*tting myself then...at least I would be consistent.
LATE EDIT: Thanks for including the definition
To Disappointed with lowered C5 :(
Old Jun 28, 2005 | 09:47 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
sorry to hear that you are so unimpressed with the new ride quality. I am also surprised that you didnt see a difference in the height of the car. With the standard F45 you should get close to an inch drop. You may want to let it settle for a few days. If you like the look, you also have the option of upgrading to bilstein shocks.
Old Jun 28, 2005 | 09:59 PM
Prosecutor's Avatar
Prosecutor
Well, I can see a drop...but it is subtle. Actually, I feel it more from the inside. Still, I didn't cut bushings or anything. I guess that is why I am so surprised at the decrease in ride quality. I understand the mechanics of shocks (roughly). I just seems that the decrease in quality exceeds the drop in height, at least based on what I hear from others after that mod.
You are right about the settling. It took mine about 150 miles to level off. I put about 370 on the clock today. Alignment is soming in the near future...and most likely new shocks.
I appreciate all of the input....thanks guys.
Old Jun 28, 2005 | 10:35 PM
canesfins's Avatar
canesfins
Would you get the same result lowering a Z06 on the stock bolts?
