Column lock update
Old Jul 1, 2005 | 03:09 PM
wps5's Avatar
wps5
Default Column lock update
Ok, so I had the "pull key. wait 10 sec..." message hit me this past weekend. I have a 2000 A4 and had the recall done some 6 to 9 months ago that removed the locking mechanism and intalled a relay harness and have had no issue. This past weekend, bam, the message and fuel being cut off to the car. So I am dead in the water, thank goodness this happened in the driveway. Anyway after reading all the post and the sticky post, and pulling fuses (#23 and #25), I found that the only way to resolve the problem was to remove the K harness from the circuit. Turns out there is an issue with recalls done that installed a k harness with a white relay. I unplugged the harneness and put the circuit back to factory and the problem is gone.
Old Jul 1, 2005 | 03:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT diagnosis and thank you for the info!!
Bill C
Old Jul 1, 2005 | 04:21 PM
Shylor's Avatar
Shylor
You have got to love GM. They tell everyone not to use an aftermarket bypass because it can cause issues. So they come out with their own bypass and it actually causes issues.
Old Jul 1, 2005 | 05:48 PM
FRCTony's Avatar
FRCTony
Note that my car had a BLACK relay that failed.
Old Jul 1, 2005 | 10:12 PM
FLL-Mike's Avatar
FLL-Mike
Default Just one more thing
I have a 6 Speed and had the recall. GM reprogramed and installed another lock. Didnt feel comfortable so I bought a CLB from Corvettes of Houston for 49.00. Local Corvette Guru at the dealership told me that it was actually a smart thing to do.
Installed it this afternoon. There was a difference in wire color "orange" as it is white in my car.
Good luck,
Mike
Old Jul 4, 2005 | 10:03 AM
Darrell G's Avatar
Darrell G
How do I find the K harness and where is this relay you are referring to? Just in case the same thing happens to me.
Old Jul 4, 2005 | 10:36 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
GM is informing dealers who call technical assistance on this issue to remove the harness K on the A4's (with the white TYCO relay only) until further notice.
Old Jul 6, 2005 | 06:12 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Ken is exactly correct... dealer did this exact operation to my 2000 A4
Old Jul 6, 2005 | 09:04 AM
WKMCD's Avatar
WKMCD
When the second dealer correctly diagnosed the problem I was having as a failure of the steering lock pin actuator the tech actually recommended the aftermarket bypass. Luckily I had one at home ready to install. They installed it for me when they were fixing the pin problem. No more problems to date.
To Column lock update
