2002 header on a 98 c5
Old Jul 2, 2005 | 01:28 PM
DAWGTUFF's Avatar
DAWGTUFF
Default 2002 header on a 98 c5
does anyone know if the longtube headers of a 2002 c5 will fit a 98 corvette? i called spl but they are closed on weekends.
thanks
Old Jul 2, 2005 | 01:31 PM
ANTIVINUM's Avatar
ANTIVINUM
I have heard that they will but you have to bend or move the EGR and something about the oil dipstick. I do not have experience with this personal so maybe some one else will chime in. TTT
Old Jul 2, 2005 | 02:26 PM
DAWGTUFF's Avatar
DAWGTUFF
thanks for your reply. does anyone know if it is just a matter of bending the egr?
Old Jul 2, 2005 | 02:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You will need to have the EGR fitting moved (welded in a new location). If they are stainless, it will be a brease for a welding shop. You just need to remove it from its present location and fill that hole, make a new hole and weld the fitting in the new location.
As for the dip stick, I would guess that you can purchase a later model dip stick and bolt it in place.
BC
Old Jul 5, 2005 | 11:10 AM
molson's Avatar
molson
you can buy a 2001+ AIR tube @ the dealer...
it connects behind the intake manifold to the existing plumbing.This will look stock and will be easier than cutting up your headers and can be easily reversed.
the dipstick can be connected to the AIR fitting by cutting the tab and drilling a hole for the bolt that connects the AIR tube to the header.
Old Jul 6, 2005 | 12:26 AM
DAWGTUFF's Avatar
DAWGTUFF
so this is all i will need to do to make it work. i got a great deal on a set of headers off a 2002 c5. have you done this mod before or do you think it should work in theory?
Old Jul 6, 2005 | 08:34 AM
molson's Avatar
molson
I am speaking from direct experience.......
I ordered a set of Dynatechs and had them coated.After installing them I noticed the AIR tube was on #5 cyl. instead of #7 where it is on the stock manifolds.The wrong header was in the right box..
I ordered an AIR tube and dipstick for a 2001+.(about $80 CDN.)
I removed the intake and the rest of the plumbing and threaded the new tube into the fitting.
It worked perfectly.
The new dipstick did not work.It sat way too high.
I think that the oil pan might be different on the 2001+ cars.....I ended up modifying the old one.
I can e-mail before and after pics if you like
Old Jul 7, 2005 | 12:56 PM
DAWGTUFF's Avatar
DAWGTUFF
thanks i really needed this info. you can send the pics to taugust@hotmail.com
Old Jul 7, 2005 | 01:45 PM
VetteNoob's Avatar
VetteNoob
Me too if you dont mind. I'll be putting on a set of 01 headers on my 99. vettenoob(NO SPAM)@hotmail.com
Just remove the (NO SPAM) part.
Thanks!
Old Jul 7, 2005 | 08:35 PM
molson's Avatar
molson
I will e-mail pics tomorrow (friday).............
Old Jul 8, 2005 | 12:25 PM
molson's Avatar
molson
E-mail sent..........
Old Jul 8, 2005 | 10:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
molson, nice info on the dipstick, i've done a few header installs recently(kooks and dynatechs on 2k's,01's, and 02 z06's)and noticed the air tube location/dipstick location difference on the 97-2000 vs 2001-2004, wasn't aware of the oil pan being different in 01>; also as molson stated these are air tubes(injected by compressor behind bumper cover on dr. side during start-up to get the cats up to temp)and not egr tubes, only the early f-body ls1's had egr
Old Jul 9, 2005 | 01:38 AM
DAWGTUFF's Avatar
DAWGTUFF
got the email. thanks for the info dude you really helped my outta of a tight spot.
Old Jul 11, 2005 | 10:56 AM
molson's Avatar
molson
Glad I could help!!......
To 2002 header on a 98 c5
