Thoughts on different X-Pipes
Old Jul 6, 2005 | 07:16 PM
SCannon's Avatar
SCannon
Default Thoughts on different X-Pipes
I need opinions on a full lenth X-pipe. I want one that is a direct bolt in Headers ---> Mufflers no cats. Or..... If anyone has a hook up to get a good discount somewhere?
Thanks..
Old Jul 6, 2005 | 08:48 PM
MisterC's Avatar
MisterC
My apologies if I'm wrong, but I don't believe anyone makes a bolt-on x-pipe. Cutting, but not necessarily welding, is required.
Old Jul 6, 2005 | 10:01 PM
SCannon's Avatar
SCannon
This is off of the WCC site:
Everyone knows the quality of Corsa, well the quality continues with this bolt on 100% Stainless Steel X-Pipe. This X-Pipe will bolt up to any after market or stock muffler system and comes with all necessary hardware.
MAGNAFLOW'S HIGH PERFORMANCE X-PIPE, Will increase performance to any C5. Made of 100% Stainless Steel and will bolt up to any C5 muffler System. Up to 8 HP gain. Simple installation requires no welding.
Made of 100% Stainless Steel, this X-pipe will fit onto any aftermarket C5 Muffler system. Eliminates almost all of the popping upon rapid deceleration. Adds 6-8 horsepower and 12-14 lbs of torque. Balances out back pressure between the left and right banks of the engine. This is an exclusive WCC Performance Product.
I figured they would just Sleeve on in the front and bolt to the back?
Old Jul 7, 2005 | 12:17 AM
Last C5's Avatar
Last C5
Well they do sleeve in up front and bolt up in the back. But, you have to cut off the existing pipes to length for the new x-pipe to sleeve to.
From the pictures I've seen the Magnaflow and Bassani seem to be true x-pipes while the Corsa is more of a blended X. I have the Magnaflow and the quality is excellent.
Old Jul 7, 2005 | 09:35 AM
mdhmi's Avatar
mdhmi
I've had both the Dynatech X-Pipe and Magnaflow X-Pipe. Both are fine.
Mark
Old Jul 7, 2005 | 09:48 AM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
I heard that the random tech x-pipe cats setup requires no welding or cutting since you are replacing the cats as well, is that true?
Old Jul 7, 2005 | 09:51 AM
t56gen3's Avatar
t56gen3
I read somewhere that if you buy the catless Bassani x-pipe and the one that keeps the cats in place you can bolt them together and not have to cut any factory piping; it makes a bolt-in replacement.
Old Jul 7, 2005 | 10:16 AM
not08crmanymore's Avatar
not08crmanymore
Default x
i have the kooks setup.headers,hi-flow cats,3x3 x pipe.very nice system.
To Thoughts on different X-Pipes
