high rev rpm idle
sometimes when i come off a turn and have to come to a complete stop ... like runout 1st gear and then have to put the clutch in and stop the car pretty quick due to a red light
.. the engine will still rev at like ~1000 / 900 rpm for a few seconds before coming back down to 650/700
is this due to the energy in the springs? or maybe my throwout? or wha ... honestly i dont really know and am just making guesses at this point.
thanks.
Kyle
verses pressing the break on an automatic where there is still gas being applied .. but i'll check the TB tomrrow.
looking to diagnois a problem with my car ...
the revs whenever I put the clutch in wont drop down right away and will continue to stay around 1500 for a few seconds and then drop down .. orginally i thought it might be my throw out bearing and the clutch not releasing but somebody else thought it might be a fouled up TB so here are some pics .. any thoughts?
the only reason i even ask if because i know there is a connection to the valve cover through to the TB which means some oil must pass so i guess .. is this normal? or would it be beneficial to clean it out.
thanks.
Rev the engine to five grand and quickly close the throttle. see if it goes right to idle.
If you have access to HP Tuners, it can pin point the problem.
Bill C
Bill C
and the only code i pulled, of any importance, was B0521H which is a tach malfunction .. but even if it was just the tach that was malfunctioning it wouldn't explain why the engine still was messed up unless for something reason the tach was part of the computer's calculation
.. but it's in the history now anyways so ..
i dunno .. i'll wait for it to reappear and go from there ..
btw .. thanks for giving me a reason to rev her up to 5 g's in the garage ..
... i'm sure my neighbors were thrilled.
BC
Take that baby to the dealer and let them fix it!! BC
it's got 51k on it and is on the ext. warranty which costs me $50 for them to fix anything.
BC
Circuit Description
The instrument panel cluster (IPC) recieves engine RPM information from the powertain control module (PCM). Engine RPM input information is obtained from the PCM on a dedicated engine speed input to the IPC. The IPC also receives engine RPM data on the serial data line. The PCM is responsible for processsing and sending engine RPM data to the IPC. The IPC will only display the engine RPM data that way sent by the PCM The IPC monitors the eninge RPM output information sent from the PCM for an out of range condition.
Conditions for Setting the DTC:
- The IPC detects that the engine RPM is at least 7,400 RPM
- The above condition must be present for 1 second.
Actions taken when DTC sets:
- The IPC stores a DTC B0521
- The IPC displays engine RPM at 7,400 RPM
Conditions for Cleaing the DTC:
- The IPC detects that the engine RPM is less than 7,400 RPM
- A history DTC clears after 50 ignition cycles (minus condition)
- Code is cleared
The following conditions may cause an intermittent malfunction to occur:
- The PCM is unable to process the correct RPM data.
- Intermittent or erratic RPM signal sent from the PCM
* for intermittents and poor connections refer to Testing for Intermittent and Poor Connections on page 8-21 in Wiring Systems
soooo .. i know where i'll be heading next.
thanks for the help.
