Pasenger window
Old Jul 8, 2005 | 11:20 PM
tazinhawaii's Avatar
tazinhawaii
Default Pasenger window
I can't believe I can't find anything in the archives on this, but my passenger side window has p*ssed me off beyond belief. It just will not roll down. I can heart the relay click when I press the switch (either on the drivers door or passenger's door). So today I tore the passenger side door panel apart and gotthe regulator unmounted. The motor was extremely hot. So I guess the motor is probably shot. How do I get the whole regulator assembly out?? Who the hell came up with a pulley and cable system in these cars. They should be SHOT!!! But is there any directions on getting these motors out of the door? Where can I get a new one? And how much has anyone paid for a new regulator/motor?
Thanks for any help.
Derrick
Old Jul 8, 2005 | 11:32 PM
mnotx's Avatar
mnotx
Sorry, but I wasn't able to post the pics.
Window Regulator Replacement
Removal Procedure
Caution
Disconnect the power window switch when working inside the driver's door. When operated, the Express Down Feature allows the door window to drop very quickly, without stopping, which could cause personal injury.
Important
The regulator and the motor are serviced as an assembly.
Remove the door trim panel. Refer to Trim Panel Replacement - Door .
Remove the water deflector.
Remove the radio speaker assembly from the door.
Disconnect the electrical/audio connector.
Remove the speaker retaining screws.
Remove the plugs from the window clamp sight access holes.
Remove the door window. Refer to Window Replacement - Door .
Disconnect the regulator motor electrical connector.
Remove the front plug from under the bottom of the door.
Mark the location of the regulator to aid in reassembly.
Remove the nuts from the regulator lower channel studs.
Remove the nuts from the regulator motor studs.
Remove the regulator rose bud clip from the door.
Remove the nuts from the upper regulator channel studs.
Fold the regulator and remove the regulator through the door inner opening.
Installation Procedure
Caution
Adjust the regulator jack screws to match the old regulator if replacing the regulator.
Fold the regulator and insert the folded regulator into the door with the motor forward.
Position the motor studs through the door inner panel.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the nuts to the motor studs. Tighten
Tighten the window regulator motor nuts to 10 N·m (89 lb in).
Install the regulator channel studs through the holes in the door.
Install the nuts to the regulator channel studs in the following order:
Upper forward
Lower forward
Upper rearward
Lower rearward
Install the regulator rose bud clip to the door.
Tighten the window regulator channel stud nuts. Tighten
Tighten the regulator channel stud nuts to 10 N·m (89 lb in).
Connect the electrical connector to the motor.
Reconnect the window switch and raise the regulator to the full up position.
Install the window. Refer to Window Replacement - Door .
Adjust the window to align with door opening.
Install the plugs in the window clamp sight access holes.
Install the uppermost screw mounting the speaker assembly to the door.
Install the remaining screws in a criss-cross pattern. Tighten
Tighten the door speaker assembly screws to 3 N·m (27 lb in).
Connect the electrical/audio connector.
Install the water deflector.
Install the door trim panel. Refer to Trim Panel Replacement - Door .
Check the window fit, adjust as necessary. Refer to Window Height Adjustment - Door Major or Window Tip-In Adjustment - Door or Window Height Adjustment - Door Minor .
Install the access plugs into the bottom of the door.
Document ID# 657154
Old Jul 8, 2005 | 11:37 PM
mnotx's Avatar
mnotx
Here's the rest.
Removal Procedure
Remove the door radio speaker assembly.
Remove the screws mounting the speaker assembly.
Remove the window clamp sight access plugs.
Reconnect the window switch.
Reposition the window full up to access the window clamp nuts.
Disconnect the window switch.
Mark the location of the window.
Loosen the window clamp nuts.
Remove the window through the top opening of the door.
Install the window, through the top of the door, to a regulator that is in the full up position.
Align the rearward glass clamp within the alignment marks on the window.
Loosely tighten the rear window clamp nut.
With the aid of an assistant standing outside the vehicle position the window to the door opening.
Notice
From inside the vehicle tighten the window clamps. Tighten
Tighten the window regulator window clamp nuts to 10 N·m (89 lb in).
Open the door and install the window clamp access plugs.
Install the uppermost screw mounting the radio speaker assembly to the door.
Tighten the door speaker assembly screws to 2.5 N·m (22 lb in).
Perform minor height and tip-in adjustments as necessary. Refer to Window Height Adjustment - Door Minor or Window Tip-In Adjustment - Door .
Old Jul 8, 2005 | 11:40 PM
mnotx's Avatar
mnotx
If you need the full illustrated instructions, send me your e-mail address and I can send them. I just don't have the ability to post pics on this site.
Old Jul 8, 2005 | 11:49 PM
Av8ter's Avatar
Av8ter
Open the door, operate the switch and slam the door at the same time. It will give the brushes in the motor a little shake and will probably start working again. Thats what I did and it works so far.
EDIT: nevermind, youve already torn it all apart.
Old Jul 9, 2005 | 12:04 AM
tazinhawaii
I've done the slamming the door thing many times in the past, but it's just not working any more. Actually, it never really worked. The window has probably worked about 60% of the time since I got the car 10 months ago.
mnotx,
Please send me the illustrated directions. The directions you sent help A LOT, but I can always use pictures.. My e-mail address is :
derrick-theresa@hawaii.rr.com
Thank You VERY much.
Derrick
To Pasenger window
