Please help with code
Old Jul 10, 2005 | 12:58 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default Please help with code
I was setting in my vette and was letting it run and the gas gauge went to empty and then went back to normal. I got home and checked the codes and it said p0463. Anybody know what this means?
Old Jul 10, 2005 | 10:38 AM
David426's Avatar
David426
P0463 Fuel Level Sensor 1 Circuit High Voltage ECM. I got this code 1 time, hit the reset button and never had any problems. If you keep getting this code or problems with the fuel gauge, I would have it looked at.
Old Jul 10, 2005 | 11:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is an excellent code web site:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
C5's have a common issue with the fuel sending units. The wire wound resistor in the unit gets dirty. Your best bet is to try the simple fix. Run some fuel system cleaner through the tank. Try Chevron Techron or Red Line.
Bill C
To Please help with code
