Callaway Honker results...
Old Aug 15, 2005 | 12:45 AM
  #41
striper's Avatar
striper
I also have the Honker. I installed it on my Z06. First of all, one of the reasons I chose it is because the quality was one of the best I've seen. Has an OEM look to it. The instructions were far better than other brands, too. They include every fastener you'd need including the correct size drill bit for the rivets supplied. Installation was not difficult and removing the shroud is not that hard to do. As far as the price is concerned, if you add up all the parts you'd purchase with another brand of intake to accomplish the same thing, you'd spend at least as much if not more. My two concerns I put to the contact at Callaway were water ingestion and computer tuning. The lowest point of the intake cutout is no lower than the stock intake. Because of the direction airflow takes as it enters the filter, they didn't feel that water would be an issue forcing its way up the intake. They have no reports of a Honker having hydrolock problems. He also said they did test it driving in rain. BTW, the filter cutout is 7" x 18". Another point he made was that they do not feel it is necessary to do a tune unless you've made other significant mods. Mild mods do not necessarily require a retune. However, in the Vette article that showed the install, on a car that had some previous work they got 34 hp with the Honker and a retune, 19 before the retune. This was over the Blackwing the car already had. Now for my own results with it. I recently ran it at Englishtown and it felt much stronger than previous runs with only a change to the Honker and a Magnaflow catback. I ran essentially the same E.T.'s as before the mods but that's because I kept having to lift due to spinning the tires on my 2nd and 3rd shifts. There was a significant power increase because my mph was up.
Old Aug 15, 2005 | 10:03 AM
  #42
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
I just installed mine this weekend. WOW the instructions were great (when is the last ime you heard anybody say that?). Any 16 year old with a toolbox could make this happen.
As for results:
I had a dyno run less than 2 weeks ago, and I am hoping to get another one done by the end of the week. Yeah, the weather will not be the exact same, but it's the best I could manage. It should be a good gague since the callaway is the only change. I am going to get a dyno tune, so I'll compare the baseline from that session to the previous pull and get an idea of just the callaway.
I have Kook's LTs, high flow cats and a Corsa cat-back. The previous pull showed 331 (331.9 actually) rwhp, with the A/F being a good bit fat. I am very confident from the "SOTP dyno runs" this weekend that I will beat my goal of 350rwhp by a clear margin.
Old Aug 15, 2005 | 05:49 PM
  #43
BradCZ06's Avatar
BradCZ06
I agree with striper. The quality is very good. Didn't do a before after dyno though so I don't know what I gained. Seems to pull harder at higher RPMs than before. Don't regret the purchase. That OEM airbox has a tiny opening for outside air to enter.
Old Aug 16, 2005 | 04:19 PM
  #44
eb02z06's Avatar
eb02z06
St. Jude Donor '08
Isn't the MTI rammer exactly the same?
Old Aug 16, 2005 | 05:35 PM
  #45
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default ...not even close
No.
The biggest feature of the Callaway Honker is the way they engineered it to fit precisely and the moving of the Mass Air sensor to just before the throttle body
G.M.'s engineers must have taken note of this, as the MAF is up in that place in the C6
I hope this helps
Old Aug 16, 2005 | 10:16 PM
  #46
striper's Avatar
striper
In addition to all other positive comments about the Honker, it is the only intake I've seen that utilizes the stock air bridge mounts on the radiator cover to keep it aligned and in place.
Old Aug 16, 2005 | 11:22 PM
  #47
shurite44's Avatar
shurite44
Actually any of the aftermarket intakes that utilize the stock air bridge would also be utilizing the mounts on the radiator cover to keep the system aligned. Vararam, blackwing, wide mouth, BPP Vortex Ramer Cold Air System, Dual Cone Air Intake all utilize the stock air bridge. The BBK Cold Air Induction System has it's own air bridge but it has holes for the stock air bridge mounts.
Old Aug 16, 2005 | 11:26 PM
  #48
Dark-Knight's Avatar
Dark-Knight
Good info, thanks!
Old Aug 17, 2005 | 12:21 AM
  #49
vetterlatethannever's Avatar
vetterlatethannever
Originally Posted by stano
Also, in all fairness, the green Wick filter is much larger than the Vararam or any other filter I've used ( Halltech included )
Stano
It looks larger than the Vararam, but to say that it is larger than the Halltech or similar filters is ridiculous. Now granted I haven't seen this filter in person (but as it looks in the pic), don't forget the Halltech is a 360* filter, not just a one-way flow-through type. Correct me if I'm wrong.
Old Aug 17, 2005 | 12:26 AM
  #50
stano's Avatar
stano
I've been known to make ridiculous statements before
Old Sep 1, 2005 | 07:55 PM
  #51
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
Originally Posted by Fozzy_Bear
As for results:
The dyno pull after changing only the intake was a solid 9-11 ft/lbs of torque uniformly across the rpm range. For a total of exactly 10 rwhp differance at the peak (341.9 vs 331.9)
I could not do it the same day, so it is not exactly scientific, but it was just a little bit hotter the second time, so the results may have been a touch better if I have done a back-to-back comparison.
Old Sep 5, 2005 | 10:36 PM
  #52
DDsC5's Avatar
DDsC5
Default Help With Intake Selection?
I am in the process of upgrading my OEM intake/filter on my 99...have been looking at the Halltech Stinger,K&N, and Blackwing, but would like to get some guidance if possible. Can anyone give me some comparisons(ie-pros/cons, HP gains etc) between each of these; that might help me in my selection process. I have only ever experienced K&N filters, as I run them in my other vehicles.
Thanks for any help -DD
Old Sep 6, 2005 | 03:04 AM
  #53
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by *89x2*
Here are a couple - Hope this helps
That filter looks like the stock size? Filter area does not look like it
matches the Stinger filter head, and noway matches the ssm
Old Sep 6, 2005 | 11:35 AM
  #54
Tru_Ice's Avatar
Tru_Ice
10 rwhp over your previous induction setup. What were you running before?
Old Sep 6, 2005 | 12:07 PM
  #55
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
Stock except for a full exhaust (details in post number 42 in this thread)
I was unable to do custom tuning at the time. Hopefully I'll get a chance this week and possibly hit my 350 rwhp goal. 8 rwhp (which turns out to be under 2.5% difference) from tuning doesn't sound unreasonable, so I am optimistic.
Old Mar 12, 2013 | 12:04 AM
  #56
cosmiccharlie's Avatar
cosmiccharlie
Thanks for all the help from everybody. I guess ill either go honker or varraram, or blackwing.
Old Mar 12, 2013 | 10:11 PM
  #57
Quil's Avatar
Quil
Wow, you bumped a thread that was 7 1/2 years old. Well done.
To Callaway Honker results...
Old Mar 13, 2013 | 12:24 PM
  #58
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
yeah... GREAT... Thanks..
Now I miss my old C5...
(but that will probably go away when I get into my C6 tonight after work )
  #59
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
Old Mar 12, 2014 | 11:45 PM
  #60
alphasurf's Avatar
alphasurf
Cruising
I found this thread very useful because I just got a 2000 Corvette and I was looking for info on which would be the best intake. Thanks to everyone who contributed to this thread and also... Sorry for floating it!
