Passenger door lock will not lock
Old Jul 27, 2005 | 11:29 PM
exracer28's Avatar
exracer28
Default Passenger door lock will not lock
Checked with tech 2, no codes and tech2 could not lock door. I can unlock and it makes noise from door module but less when trying to lock then when unlock is selected. Checked voltage going to lock motor and lock was under 1 vdc. unlock was about 10vdc.
Does this point to the door module? Any repair to module?
Old Jul 28, 2005 | 12:01 AM
Dave68's Avatar
Dave68
Almost all issues relating to doors not locking end up being because of the door lock modules. I had mine replaced under warranty a couple of years ago.
Old Jul 28, 2005 | 12:50 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
door control module...
Old Jul 28, 2005 | 08:48 AM
BBQ's Avatar
BBQ
Pretty common. Yes, its probably a door module. I had mine replaced under warranty.
Old Jul 28, 2005 | 10:05 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
What those other three guys said.. I bought mine at Fred Beans, swapped it myself, working great so far.
Old Jul 28, 2005 | 10:13 AM
darkmercury's Avatar
darkmercury
Same here... driver's door module was replaced! Locks and window were not working!
Old Jul 28, 2005 | 09:27 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Mine is going in Wednesday for the same thing... intermittent driver side (lock or unlock).
When it doesn't pop the lock, I hear a faint "tick" sound, as if the relay is closing, but not completing the circuit to energize a solenoid... anyway, my GMPP is going to cover it (and I hear it is not a cheap component).
Old Jul 29, 2005 | 12:51 AM
bindy's Avatar
bindy
I have had 3 of these go bad in 2 different year cars. I was out of warranty on the last one, so I thought let's open the module up and see what's inside. Just 2 easy latches and it opens right up. Just a fairly simple PCB with connectors on the one edge and 4 solenoid type multi-contact relays boxes on one end. I tried the unlock/lock button so I could feel which one was clicking. I desoldered this one from the PCB and carefully popped the cover off. Wala! One of the contact sets were black from arcing. A quick clean up with a small contact file and a squirt of contact cleaner and then back together. Works like new again. For how long??? It's lasted 4 months so far...
Old Jul 29, 2005 | 12:04 PM
chuck1026's Avatar
chuck1026
So I did guess how the POS is assembled. I may just repair my original unit instead of letting Mr. Goodwench rip my door panel off to repair it.
Old Jul 29, 2005 | 12:30 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Well, it appears I am having the same problem..I was praying it was a simple FOB issue, until I tried locking the passenger door with the driver door button and it still did not work..
here's my thread
http://forums.corvetteforum.com/show...565&forum_id=1
Old Jul 29, 2005 | 03:13 PM
exracer28's Avatar
exracer28
That is just what I wanted to hear. I will pull it apart this weekend and see what the contacts look like. Perhaps adding a better relay might improve it's life. I am going to check for any unused contacts on the relay to see if I can swap contacts.
Old Jul 29, 2005 | 04:34 PM
Joe C5's Avatar
Joe C5
I cleaned the contacts on the door latch module just this last weekend. It's been working ok since - sounds like a new relay is in the future for me too (probably cleaning the contacts got me just over the edge for now). I'm guessing since they only have one coil (?) they were cheap and failed to put in back to back Zener Diodes to save the relays (I will look when mine dies again).
Old Sep 27, 2005 | 09:35 PM
604_c5's Avatar
604_c5
Default yi
yo guys~~~ i kno this is an old post..
but my the same **** is happenin to my locks..
and i went down to Chevrolet today to get them replaced..
but after i got there, i didnt cuz the friggin door control modules are $500 for 2 pieces (drivers side n passenger)
anyone know where i can get good door control modules at a better price?.. or are they just that expensive?!????
im in canada btw! haha
thanks..
Old Sep 28, 2005 | 12:01 AM
NIX's Avatar
NIX
Check out this thread:
http://forums.corvetteforum.com/show...ule&forum_id=1
Drivers side door would not unlock so I replaced the unlock mini relay following the direction of this thread. Took me a couple of hours and saved a lot of money. Hope this helps.
To Passenger door lock will not lock
