cam spec question
Old Jul 29, 2005 | 06:08 PM
Apollyon's Avatar
Apollyon
Default cam spec question
Okay dumb*** question folks. Can anyone tell me how to check the lift int. and exh. on a camshaft? I just bought one at a swap meet from a fellow vette guy and it is a custom ground cam with these specs that I know: 228/228 112lsa. He is going to find his spec sheet when he gets a chance, but I was just getting a little ansy to check all of the specs, and look at a set of heads that would be a good compliment to the cam. Any input would help thanks.
Old Jul 29, 2005 | 06:52 PM
vettenuts's Avatar
vettenuts
Measure the base circle of the lobe then the height across the base circle and peak of the lobe. Subtract one from the other.
