MAF T-25 tool ?????????/
Old Jul 31, 2005 | 09:41 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default MAF T-25 tool ?????????/
I know the ups and downs of removing the MAF screen, and cutting out the huge bar in the middle of the unit, But I wanted to do that today. The problem is I thought I could take off the 4 screws that hold together the MAF housing with an allen wrench, but you cant. It takes a T-25 tool
Where can I get a T-25 tool, so I can screw up my car !!
Old Jul 31, 2005 | 11:35 PM
GrayC5's Avatar
GrayC5
The screws are TORX screws and you need a TORX bit or TORX bit screwdriver. You should be able to find them at Sears or most any automotive or hardware store. You can buy TORX tools individually or in sets.
TORX Tool Specifications
Old Aug 1, 2005 | 12:37 AM
leaftye's Avatar
leaftye
You can find them at most auto stores. I bought mine from Pep Boys and Autozone.
Old Aug 1, 2005 | 09:31 AM
2000BSME's Avatar
2000BSME
If you need help locating simple tools like Torx bits, I would say that you are lacking the basic mechanical skills necessary to be screwing with your car in the depth that you are currently considering.
I see bad things happening if you persist.
Old Aug 1, 2005 | 11:06 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The screen is one thing. You remove the bar the sensor is now useless. You will throw codes all day. The bar is needed. It has sensors attached to it.
Old Aug 1, 2005 | 12:06 PM
99 vett babycar's Avatar
99 vett babycar
DO NOT screw with the bar !!! Buy a SET of torx screw drivers, you're going to need them.
Old Aug 1, 2005 | 12:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TAKE THIS FROM EXPIERENCE!!!!!!!! If you screw with the MAF and the air flow going through it, You WILL have performance issues!! That is not to say that you cant fix the problems. That will require a tune!! If you think you need more air flow and want to alter the MAF, be prepaired to spend the bucks to tune it!!!
What MOD's do you have to support the need for more air flow? The stock MAF will support way more HP than most bolt on mods will offer!
MY 2 cents.
Bill C
Old Aug 1, 2005 | 09:19 PM
phils C5 vette
an *** new member like you is not worth commenting on.
I asked the better members on here where to get a tool.
I went back and checked your threads, and if you like to keep making stupid remarks to everyone on the forum, you'll be throw off before your soon to be new wife can give you a tissue.
normal forum members, the bar I was talking about is NOT the sensor bar. Its the air direction bar. it's part of the port and polishing of the housing.
Old Aug 1, 2005 | 09:30 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Phil, step away from the car.. leave the MAF alone. There is going to be no gain in messing with it..
Old Aug 2, 2005 | 11:54 AM
screw991le's Avatar
screw991le
Pull up a chair
Old Aug 2, 2005 | 01:58 PM
2000BSME's Avatar
2000BSME
I'm sorry I made you pout. I'm glad you are checking my threads. Like most of the other members in this forum have said, in agreement with my remark, leave it alone.
The tool you are talking about is a simple item that anyone proficient in turning a wrench would know where to find. I deduced that your general lack of knowledge regarding tools should be a fair warning to you in using them on something you seem to know very little about.
Opinions are welcomed by most of the people on this board, including "disagreeing" or "differing" opinions. I'll put you on my "ignore" list so as not to ruffle your panties again.
Old Aug 2, 2005 | 02:39 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Old Aug 2, 2005 | 07:54 PM
phils C5 vette
Ok Chris thanks
I was bored sunday and thought about doing it while I cleaned out the vararam filter. which I might *** after 6000 miles, was pretty clean.
I thought while I was in the induction, Id do the MAF. You I listen to.
OK enough of this thread
To MAF T-25 tool ?????????/
