Looking for longer wheel studs
Old Aug 2, 2005 | 09:46 AM
tahoeC6's Avatar
tahoeC6
Default Looking for longer wheel studs
I have been running CCW's with Kuhmos for track trials and I would like to get a few more turns on the threads. Does anyone know who carries a longer wheel stud?
Old Aug 2, 2005 | 10:10 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
At the risk of not answering your question..
A good friend and machinist of 30 years (builds custom tools to assemble F-16, 22, etc. HP planes for the Govmt.) told me that as long as you have the same amount of area engaged "lengthwise" as the diameter of the fastener, any more does not significantly strengthen holding power.
So, if your stud was .5 inch in diameter, as long as you engaged .5 inch worth of threads, you are fine.
Old Aug 2, 2005 | 10:31 AM
RoHo's Avatar
RoHo
Napa
Old Aug 2, 2005 | 10:32 AM
RoHo's Avatar
RoHo
Try your local Napa auto parts store
Old Aug 3, 2005 | 06:45 PM
tahoeC6's Avatar
tahoeC6
Thanks Dan, I'll check and see where I am.
Old Aug 3, 2005 | 06:56 PM
Z11409's Avatar
Z11409
ARP studs and GM racing or any REAL auto parts store.Stud is the same as most GM cars.
Old Aug 3, 2005 | 07:46 PM
AU N EGL's Avatar
AU N EGL
ARP Studs from Summit Racing dot com
I needed longer lug bolts as I use a 3/8" spacer on the rear with 18x12" CCW rims
also get some good ARP or hardened lug nuts dont use the stock lug nuts.
They wont have the aluminum caps on but your wheels will be secure.
Old Aug 4, 2005 | 09:49 PM
tahoeC6's Avatar
tahoeC6
Default Thanks
I'm feeling more "studly" by the minute!
To Looking for longer wheel studs
