Having tranny problems need help
Old Aug 3, 2005 | 02:17 AM
jhong321's Avatar
jhong321
Default Having tranny problems need help
Hello All
I just got this car about 4 days ago and somthing wierd is happening.
When I come to a complete stop and put the car in neutral then back in to gear it goes in to gear fine but there is a gear grinding sound when i give it gas( Kindof like when you try to put in gear with out steping on the clutch) The car still takes off fine and runs threw all the gears. It only happen when I come to a complete stop. It does Have a aluminum flywheel and a spec III clutch. can anyone help me
Old Aug 3, 2005 | 11:12 AM
Z O SICK's Avatar
Z O SICK
It could be your spec clutch. I've heard that they chatter on some cars. My spec III never chattered. I hope it's this nad nothing major.
Old Aug 3, 2005 | 11:56 AM
djengr's Avatar
djengr
Originally Posted by jhong321
Hello All
Is the noise coming from the rear of the car or in the transmission area. Mine has a 1st gear rumble or growl, not necessarily a gear grind. Mine definately comes from tranny and I have heard similar noise on others. BTW as far as I know mine is completely stock.
Old Aug 3, 2005 | 02:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
You may hear noise on a regular basis with that light flywheel. The heavier/stockers soak up a lot of that so they are quiet. You should hear a ZF6 with a Fidenza..Sounds like a damn diesel idling.
Old Aug 3, 2005 | 08:04 PM
jhong321's Avatar
jhong321
I have heard about the aluiminum flywheels but this is notting like that it's louder than the car a wOT And definitly a gear grinding sound. And it just happen yesterday (Before that it was fine just a little chatter every once in a while). I will be having it towed to the shop in the morning.
Old Aug 3, 2005 | 08:06 PM
jhong321's Avatar
jhong321
Old Aug 4, 2005 | 01:54 AM
cv67's Avatar
cv67
St. Jude Donor '05
And at times under full throttle it can sound like the tranny is coming through the floor! I realize the C5 is a quite different, but the symptoms of light flywheels are very similar. Ask Mojo to see his in car vid of his 1/4 mi. pass on his 6 speed car: When he hits 4th gear I bet its a similar sound
Old Aug 4, 2005 | 04:05 AM
kirbyloid's Avatar
kirbyloid
Default trans
Hello All
Give Rodney a call you can find his number in my sig he is the Top trans guy around and can quickly assess your issues
Old Aug 10, 2005 | 06:12 PM
jhong321's Avatar
jhong321
Found the problem it was a bad pilot bearing. I can't believe a $10.00 part cost so much to put in at least i was able to look at the clutch and flywheel ( which are still in perfect condition)
To Having tranny problems need help
