Check Engine Light
Old Aug 4, 2005 | 01:54 PM
frenchcu's Avatar
frenchcu
Default Help with codes
I just installed new pads, rotors and SS brake lines on my friends C5. Is there anything I could have done to make the Check Engine Light come on? I don't recall it being on before and I am not sure if it is something I did.
Any help would be appreciated.
Old Aug 4, 2005 | 02:36 PM
Silver98's Avatar
Silver98
What codes is it throwing?
Old Aug 4, 2005 | 02:44 PM
frenchcu's Avatar
frenchcu
Default Codes I just checked
Ok I checked the codes maybe it has nothing to do with what I did.
The codes are
B0361 H C Actuator feedback circuit
P0161 H C ho2s heater performance
I do not know what they mean but it does not seem to have anything to do with Brakes, I just don't recall if the light was on before and I would hate to have it now on when I give it back.
Old Aug 4, 2005 | 03:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would clear the codes and see if they come back. The P0161 H C ho2s heater performance could be caused by a bad ground. The ground for that circuit is located in two places. One is on the drivers side of the block just aft of the engine mount. From there it goes to the chassis ground stud located on the frame rail, directly below the brake master cylinder. If you clean both of those grounds and still have the problem, you could have a bad O2 sensor or sensor wiring.
BC
Old Aug 4, 2005 | 03:29 PM
frenchcu's Avatar
frenchcu
Anybody have any ideas? I have to do something soon.
Old Aug 4, 2005 | 10:49 PM
djengr's Avatar
djengr
This is what I have on the codes
99-HVAC - Heater, Ventilation, Air Conditioning
B0361 Left Actuator Feedback Short to GND
10-PCM - Powertrain Control Module
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
Try reseting and see if they come back. I believe the Oxygen sensor would set the check engine light the other would not. Nothing to do with brakes.
Old Aug 5, 2005 | 12:23 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
I guess my suggestion doesnt count!
BC
Old Aug 5, 2005 | 09:47 AM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
The Check Engine Light comes on for a reason; either legitimate or not. Mine came on a few weeks back and it was nothing more than a loose connection. It only cost me $30 at the dealer for their time. Of course I have a friendly/trust worthy service advisor. Oops, thought I would never say those words together in a single sentence.
Old Aug 5, 2005 | 09:58 AM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Default check engine light
The number one cause is still a lose gas cap
Ron
Old Aug 5, 2005 | 10:05 AM
99 vett babycar's Avatar
99 vett babycar
BC
Bill, your suggestions ALWAYS count
To Check Engine Light
