Problems launching at the track
I am bogging off the line or blowing the tires up in smoke. If I launch from Idle the car bogs (converter doesnt seem to flash to 3800) and if I launch from 2k or higher it spins like crazy. I tried 1000-2000 launches but they are still in the 1.9 range.
Once I get moving the car feels strong but maybe running rich. I am only getting 9 mpg in the city and 22 on the highway. I plan to scan the car tomorrow.
I am also investing possible false knock. Can headers touching the subframe cause false knock. I am going to look at the knock multiplyer tomorrow also. I lost almost 3 mph from a week ago right after the engine went in. When I put a new program in from my HP tuners the car feels strong but after a day or 2 its starts feeling slugish.
I plan on getting this fixed this week because I want to drive the vette to Houston the following week.
So has anyone else gotten such crappy 60's on drag radials or such crappy gas mileage? Any suggestions would be apreciated.
BTW: I ran this last weekend:
60' = 1.82
1/8 = 7.80
mph= 91.87
Last night when it was 5 degrees cooler:
60' = 1.92
1/8 = 7.98
mph = 89.32
WOW did I have a good time!!!! I learned a LOT!I have an 02 Z06 with Stainless Works headers and a complete 3" exhaust, VARARAM, and 305 P-Zero tires.
I learned what sleeping at the light means
I progressively got better throughout the day and when I get some drag radials, i'll be back for some more fun.My car dynoed at 375 rwhp and 365 tq.
Here is my best run.
RT - 535
60' - 2.058
1/4 - 12.729
MPH- 113.26
I was blazing the tires in 1st and 2nd. I beat the car hard all day and she didnt complain once!!
Bill C
""Once I get moving the car feels strong but maybe running rich. I am only getting 9 mpg in the city and 22 on the highway. I plan to scan the car tomorrow.""
When I installed my headers and mararam, my mileage dropped down from 29-30 on the highway 18-19 city highway all the way to 22-23 highway and 12-13 city highway.
I got her tuned and now I'm back up to 26-27 and 17-18 and the car feels much more responsive. i was very lean in most areas and the PCM was adding fuel big time!!!
Get your car tuned and you should see an improvement.
Bill
60' = 1.82
1/8 = 7.80
mph= 91.87
60' = 1.92
1/8 = 7.98
mph = 89.32
My suggestions, Tuning, tuning and more tuning. Figure out why your car is giving you such crappy fuel mileage, make sure all the shift points/trans line pressure are all in order. Your A/F and spark timing must be in line, check your plugs; running that fat will kill plugs and not allow them to run at their best. Also, let me tell you, dumping that much fuel can harm piston rings. Take care of the possible tuning issues first, then worry about the mechanical issues, if any. You mentioned knock, do you have an HP tuner software, Tech II or LS1 edit? If so, then you can see if you are getting knock after a recorded run. Yes, headers bumping into your block can cause goofy knock thus robbing you power.
Who is tuning your car? ah...it does not matter, just fix it. is this new motor NEW or USED?
The tune on the new motor is by 21st and it is very conserative. The knock senors is pulling timing from something other than knock. I am taking it over to 21st tomorrow to have them check the exhaust, injectors, and anything else that could cause the knock sensor to go crazy. I plan on going to the track this weekend to test after I get this fixed.
BC
I did a scan today and was getting 2 degrees of knock and 16 degrees of timing at WOT.
