Code P1381 for a 97 MM6???
Old Aug 8, 2005 | 10:26 AM
T.J.'s Avatar
T.J.
Default Code P1381 for a 97 MM6???
Has anyone ever had this code and what did you do to fix it? The code is "P1381 Misfire Detected-No EB (T) CM/PCM Serial Data"
TIA
Old Aug 8, 2005 | 11:44 AM
SFVetteman's Avatar
SFVetteman
The PCM detects a misfire by detecting variations in crankshaft deceleration. Sometimes driving on a rough road will mimic a misfire as interpreted by the PCM so the PCM checks the ABS data to see if the ‘misfire’ is because of a rough road. P1381 sets when there is no ABS data to check. Could be loose or corroded connectors or something with the ABS system.
