"Charge System Fault"
Old Aug 11, 2005 | 04:54 PM
WildWolf's Avatar
WildWolf
Default "Charge System Fault"
This message popped up on my DIC the other day. I pressed reset and it did not come back. Can anyone tell me why this would happen?
Thanks in advance.
Old Aug 11, 2005 | 05:15 PM
Dixit's Avatar
Dixit
I get that once in awhile but never really pay attention to it cause my Voltage always shows 14+
Dixit
Old Aug 11, 2005 | 05:28 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
same here
i saw the voltage blip down to 12ish one time on the DIC then the message came up...probably a grounding problem, dont worry about it
Old Aug 11, 2005 | 05:32 PM
jedicowboy's Avatar
jedicowboy
Mine would do this on start up. I had this for quite some time and we replaced the alternator and the ignition switch to no avail. Turned out it was like a 10 cent ground fix for the ignition switch (or somewhere close).
Old Aug 11, 2005 | 07:00 PM
WildWolf's Avatar
WildWolf
Thanks for the replies!
Old Aug 12, 2005 | 09:16 AM
2003vert's Avatar
2003vert
I was geting the same message about every 3rd start up. car was still under warranty and nothing ever sent codes to the computer. the fix was to replace the igition switch, the post above about the ground may also be correct as it is in the same place.
To "Charge System Fault"
