HELP! Having Key Remote issues.
Old Aug 12, 2005 | 09:48 AM
97C5ENVY's Avatar
97C5ENVY
Default HELP! Having Key Remote issues.
I'm not sure what's going on but my key remote seems to be playing possum. It plays dead until I re-program it through the DIC, then all is well for a few hours, and then BAM it's dead again. I changed out the battery on the remote TWICE already and it is still doing the same thing. Anyone know what might be going on here?
THANKS!
Old Aug 13, 2005 | 05:33 PM
97C5ENVY's Avatar
97C5ENVY
Anyone?
Old Aug 14, 2005 | 12:16 PM
DAWS C5's Avatar
DAWS C5
Try prying up the battery contacts (carefully) so they put more pressure on the battery. When the fob is jarred, it momentarily loses contact with the battery. Thus it is no longer in sync. This may help.
Old Aug 14, 2005 | 03:28 PM
servohead's Avatar
servohead
I had to replace my remote to correct that issue. even after a mere 20 minutes the remote would not work after relearning. The contacts in my remote were ok, new battery, still no go. I would suggest replacing the remote.
Old Sep 2, 2005 | 12:31 PM
ALLEN RUSSELL's Avatar
ALLEN RUSSELL
Navigator
Default Transmitter
Having Same Problem With My 2000. Took To Chevy Dealer
And Had Whole Systems Reprogramed . Still Did Not Work .
The Tech Called Tech Hot Line . If Your Fob Comes On Traning.
And Remote Works .then Quits After 2 Or 3 Times Replace .
Both Transmitters .i Have My Transmitters On Order Now.
Part # Is On Back Side ( Must Be Same Part # As Yours ) .
You Can Save About $40 Dollars Each At Gm Parts Direct.
On Line Just Put In Part # On Back And Will Give You Price .
About $71.0 Each .
Old Sep 3, 2005 | 10:29 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
It sounds like your remote is worn out.
If it's 8 yrs. old and you've tried everything thats been suggested then I'd say it's time to get a new one.
Check Ebay and I would suggest you stay away from used ones.
Old Sep 3, 2005 | 10:34 AM
chanderson's Avatar
chanderson
It is definetly your keyless remote. I had the same identical problem with mine. Tried everything you did and it didn't solve the problem until I took my car in for warranty work and they had replaced the key fob. Now it works flawlessly.
To HELP! Having Key Remote issues.
