Throttle Body
Old Aug 16, 2005 | 08:52 PM
DVS 99's Avatar
DVS 99
Default Throttle Body
In the market for a good throttle body. What kind of gains will I see on a head and cam car? Anyone have any suggestions on a good throttle body for a fair price.
Old Aug 16, 2005 | 09:03 PM
C5XTASY's Avatar
C5XTASY
Yep! Look at this one. http://www.lingenfelter.com/store/tbls1tk.html Top tuner, great price. I don't believe you'll be able to beat it.
Ed
Old Aug 16, 2005 | 11:34 PM
Dark-Knight's Avatar
Dark-Knight
The LPE TB sounds interesting.... Made the change on my C4 and was happy with it. Looks like it's in the C5's future as well.
Old Aug 17, 2005 | 05:05 AM
vettenuts's Avatar
vettenuts
I got mine ported by Mark Shaner. Very nice work for $170.
Old Aug 17, 2005 | 08:14 AM
IFLUBYU's Avatar
IFLUBYU
Just put mine on two weeks ago, it rocks. Throttle response is awesome, even in the mid-upper 90s and mushy air we have had here in the mid atlantic region lately. Putting it on the dyno tomorrow. Best $160 spent yet.
Good Luck!
Old Aug 17, 2005 | 09:25 AM
thefritz1's Avatar
thefritz1
Gotta agree I absolutely felt a difference in throttle respsonse. Takes less effort on the gas pedal to go now. That much is sure.
Good Luck!
Old Aug 17, 2005 | 10:50 AM
RedRider98's Avatar
RedRider98
I have been thinking about buying a ported TB. Can someone explain in more detail what porting does and what performance gains would be noticed?
Old Aug 17, 2005 | 11:02 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
How do you contact Mark Shaner?? Do you get the same throttle body back or does he exchange it with one that's already ported??
Old Aug 17, 2005 | 11:14 AM
C5XTASY's Avatar
C5XTASY
Here's the link:
http://www.s2performance.net/vettepage.html
However, IMHO, I really doubt if there's there's much, if any, performance difference between ported throttle bodies from reputable vendors.
Ed
Old Aug 17, 2005 | 12:13 PM
Rwdyryd's Avatar
Rwdyryd
I put the Shaner S2 on my car, but too many other mods to draw a conclusion about the TB separately. My throttle response is real good. Marks Shaner does nice work, keep in mind that the polished version vs the satin finish makes no more HP, so it's just a looks thing . My tuner didn't want me to get a TB, said he had quality problems in the past with other brands, but he thought the Shaner one looked good. Mark machines the body before porting so the taper to the blade is less acute in my opinion. If you go to his site you'll see one being machined.
I got one delivered, then sent back my core last week, so maybe you'll get my TB
Bob
Old Aug 17, 2005 | 12:15 PM
vettenuts's Avatar
vettenuts
I bought a used one and sent that to Mark. I also called him and he took all my information on mods as it makes a difference. For instance, a big cam will get a different porting then one with a stock cam.
Old Aug 17, 2005 | 12:17 PM
RedRider98's Avatar
RedRider98
On a stock car (except air intake and cat back) would there still be a noticeable difference or does it apply mostly to modded cars (heads, cams, headers, etc)?
Old Aug 17, 2005 | 12:20 PM
Alex1217's Avatar
Alex1217
Originally Posted by C5XTASY
Here's the link:
Ed
Thanks for posting the link.
Is the S3, the one you're talking about (the one for the big cams)?
Old Aug 17, 2005 | 01:09 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Ditto - definitely work the money! Improved throttle response is definitely noticable. I'm getting it dynoed during the first week of September when I have my F13 cam installed. The S2 is for the Corvettes, while the S3 is for the F-bodies (electronic control vs. wire).
Good Luck!
Old Sep 6, 2005 | 07:36 PM
JIMI156's Avatar
JIMI156
8th Gear
Default Tb
I'm also interested in purchasing a new TB. I was wondering, is there a period of time it takes the cars computer to adjust to the increased air flow, or can you feel the difference right away and are most of the TB sold ported to the same diameter?
Old Sep 7, 2005 | 01:24 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The blade remains 78 mm - so porting doesn't increase diameter.
LPE and Shaner shouldn't cause idle problems although PCM learning will occur to compensate in airflow change.
I had an LPE and it worked very well (H&C car). Only reason I removed it was to go to a 90mm Fast intake.
FWIW.
Old Sep 7, 2005 | 05:55 AM
JIMI156's Avatar
JIMI156
8th Gear
...should I go with a ported TB or go for one of the 80mm or even a 90mm and buy a new intake manifold?
To Throttle Body
Old Sep 7, 2005 | 12:16 PM
INTHERED's Avatar
INTHERED
Originally Posted by Rwdyryd
Marks Shaner does nice work, keep in mind that the polished version vs the satin finish makes no more HP, so it's just a looks thing Mark machines the body before porting so the taper to the blade is less acute in my opinion. Bob
After all this machining and polishing does the clearance between the
throttle blade and the throttle bore change ? especially when fully closed ?
INTHERED
Old Sep 7, 2005 | 04:27 PM
craig04c5's Avatar
craig04c5
I'd like to know also.
Old Sep 9, 2005 | 08:08 AM
adf's Avatar
adf
Default throttle body and MAF
I recently purchased a 99 C5 and a couple of mods were done at that time i.e. K&N dual air intake,borla cat back.i have added ls6 intake manifold and a 160 degree thermostat. I am considering a BBK 80 TB and Granatelli MAF sensor. Am I wasting my money to get the additional HP? I am heading to Summit racing in Akron tomorrow to receive a 10% discount on special event day. My goal is to only go a little faster at a local dragstrip. I am not a serious racing guy. just for kicks! thanks out there. i am new to all this at the ripe age of 55.
