Dynatech SuperMAXX headers - How do you like them?
Old Aug 21, 2005 | 04:02 PM
sting66cp's Avatar
sting66cp
Default Dynatech SuperMAXX headers - How do you like them?
I am thinking about a set of Dynatech SuperMAXX headers as one of the first mods for my stock 2001 C5. Any good or bad news to report with these? Can they be installed in a garage, or is a lift required? They are stainless steel but I was thinking about having them coated anyway to help reduce heat. What are your thoughts?
Old Aug 21, 2005 | 04:07 PM
Dustydog's Avatar
Dustydog
Cruise-In VI Veteran
Cruise-In VII Veteran
I love them!
I installed them last May in my garage on jackstands.
I had the sent out and Jet-Hot coated before I installed. I have had no problems with them and would install them again.
Very high quality and fitment.
Hope this helps
Old Aug 21, 2005 | 05:42 PM
sting66cp's Avatar
sting66cp
Originally Posted by Dustydog
I love them!
Hope this helps
Great feedback, thanks. How high did you have to jack up the car to get them installed? I'm assuming they install from the bottem.
Old Aug 21, 2005 | 05:54 PM
lar66BB's Avatar
lar66BB
Default headers
I love them!
Hope this helps
I had mine installed about 2 weeks ago, I did the complete system
high flow cats and x-pipe. They make a lot of torque. Diffenitly louder
and more inside rumble. I personaly like it, but may be too much for
some.
Old Aug 21, 2005 | 06:56 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
I had mine installed about 4 weeks ago and I am really enjoying them!
Old Aug 21, 2005 | 07:46 PM
ecook's Avatar
ecook
How much horse power do you get from the Headers?
Old Aug 21, 2005 | 10:57 PM
Rex99Coupe's Avatar
Rex99Coupe
I installed mine this weekend on jackstands in the garage, jackstands sitting on top of 2x10's, so about 23" for front and about 20" with jackstands for rear. Had mine coated by Jethot, installing them did scrape some of the coating off. I installed them by myself, so it took some time getting them to fit in. Difficultulties were the air conditioning tubes on the passenger side, I had to pry the tubes out of the way to get the header to drop in. The driver side was the easiest because I jacked up the bell housing 1/2" as described on LS1HOWTO.com (installing LGM longtubes), also had to disconnect the ground strap form the block as described on LS1HOWTO.com.
I had to remove the coilpacks from both sides and the valve cover and loosen the starter from the passenger side.
The things I would do if doing it again: before installing the headers, after the stock exhaust is out, I would loop a zip tie in the holes in the frame on the passenger side, maybe two at different locations so that you could attach a ziptie around the 02 sensor wire to keep the 02 wire away from the header. I found this to be difficult with the header in place, but not bolted in position. I would recommend using the instructions on LS1HOWTO.com as they list bolt sizes and torque values and tend to cover items glossed over by Dynatech Instructions.
The items I would consider before buying and installing are, the headers will be in the way if replacing the clutch and starter motor. I don't know if they could be unbolted or have to be removed to make these repairs.
Old Aug 21, 2005 | 11:50 PM
MUKAK's Avatar
MUKAK
I love mine.................
Old Aug 22, 2005 | 04:13 AM
ELECTROVERT 02's Avatar
ELECTROVERT 02
Had mine installed a few weeks ago with Z06 exhaust. Love 'em! Also added koolsox to plug wires in case of heat issues just to play it safe. Had it edited and dynoed. Nice sound - mellow until you get on it. Well worth it. Quite a SOTP difference. Good luck!
Old Aug 22, 2005 | 06:34 AM
Z06 Steve's Avatar
Z06 Steve
they are top notch.Install tip pass side remove the plastic shield around the battery.header goes in from the top without having to remove the starter.car has to be atleast 22" frame to floor high for driver side install.
Old Aug 22, 2005 | 06:42 AM
WKMCD's Avatar
WKMCD
Old Aug 22, 2005 | 07:19 AM
C5XTASY's Avatar
C5XTASY
Ed
Old Aug 22, 2005 | 10:01 PM
bikeone's Avatar
bikeone
Love mine. Nice fit.
Old Aug 23, 2005 | 08:56 AM
Heretic's Avatar
Heretic
Nice header. Anyone who tells you they don't make power like the other brands is spoofing you.
Old Aug 23, 2005 | 09:11 AM
newgene's Avatar
newgene
I love mine. I've had them for nearly 6 months, and I simply love them. They improve the tone/pitch of your exhaust to a more distinct rumble. I didn't find that they made the sound much louder, but it definitely sounded more throatier. As for performance, the torque increase feels awesome.
Before I bought them, it was between them and the LG's. I'm sure they're both good sets, but the cost difference was around $500, and I really couldn't see anything to justify the difference. I think almost all headers are within 10% of each other with respect to performance gains. I think LT headers are a must for the C5, and the Dynatechs are just a solid performing, good quality set.
Old Aug 23, 2005 | 09:12 AM
thermalracing's Avatar
thermalracing
if throw on dynatech headers, and tuned my car wich already has ram air, corsa exhaust how much hp should i see on paper, and how will it feel?
Old Aug 23, 2005 | 10:00 AM
Morzoff's Avatar
Morzoff
To Dynatech SuperMAXX headers - How do you like them?
Old Aug 23, 2005 | 12:34 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Put on the complete system two weeks ago. Had em coated except the hi-flow cats. Looks, sounds, and feels terrific. Used a lift and pretty straight forward process. The best product out there for the money IMHO.
Old Aug 23, 2005 | 12:44 PM
scottyo's Avatar
scottyo
Installed mine in May. Headers, high flow cats, x-pipe and Corsa Indy's. Absolutely freakin love em.
Old Aug 23, 2005 | 01:24 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Love it - see pix.
