From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Originally Posted by silverz06vette
You can buy the bolt seperate. Its 22 or 23 ft-lbs. I just ususally reuse the bolt with a little loctite if you like.
Thanks. Good to hear about just the bolt. I'm going to the dealer at lunch so we will see. I would reuse the bolt, but the problem is it came loose and fell out on its own
I was hearing noise and grinding, checked things out, and the bolt was gone, the caliper loose and rubbing on my wheel. The bottom bolt was also loose, but still there.
I changed brake pads over a year ago, and I guess not properly torqued.
