C1286 and engine performance
Old Aug 24, 2005 | 08:04 AM
smittydog's Avatar
smittydog
Default C1286 and engine performance
Does the C1286 when tripped affect engine performance? My car has been tripping this code for awhile and I assumed it wouldn't affect performance. I've been chasing other bugs and am wondering if this might be the root of my problem.
Old Aug 26, 2005 | 01:02 PM
smittydog's Avatar
smittydog
I'm struggling here guys.. I can't even keep up with a stock rustang. Any C1286 experts out there???
Old Aug 26, 2005 | 01:25 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
C1286 Steering Sensor Bias Malfunction
This shouldn't cause any performance reductions, what kind of problems are you trying to troubleshoot?
Old Aug 26, 2005 | 01:33 PM
smittydog's Avatar
smittydog
It's been a long dragged out H/C and exhaust swap. Some details are explained here:
http://forums.corvetteforum.com/show...634&forum_id=1
I'm just trying to make sure the C1286 code isn't causing my problem before I continue trouble shooting.
Old Aug 26, 2005 | 03:55 PM
Gordy M's Avatar
Gordy M
Did you have the steering shaft removed/disconnected during the swap. If so, the voltage is off for the sensor and the sensor is not making parity with the AH system. If you get it every time you go above 10 mph, that is the problem and it is turning AH off. No effect on the engine.
Old Aug 27, 2005 | 08:52 AM
smittydog's Avatar
smittydog
I did have the steering shaft off during the swap but I'm pretty sure I got it back in the same location. I was getting the c1286 code before I did the swap and will fix sooner of later just wanted to make sure that wasn't complicating my other problems.
To C1286 and engine performance
