Another FOB issue!!! aggrrrr
Old Sep 2, 2005 | 12:42 PM
thevelvetglove's Avatar
thevelvetglove
Default Another FOB issue!!! aggrrrr
It seems unless I am within 2 feet of my vet the signal to "Lock" the door will not work. Yet the signal to unlock the door seem to work avout 10 feet away. I replaced the battery, and it still is no different, so the question is what is going on....I am tired of replacing the FOB's
Aloha from Sunny Hawaii
Old Sep 2, 2005 | 01:47 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Need more info.
what year vette?
Are the replacement remotes new or used?
Are your wheel sensors giving you tire pressure readouts?
Old Sep 2, 2005 | 08:55 PM
thevelvetglove
Originally Posted by ROCKnROLL
Need more info.
what year vette?
Thanks 2000 coupe
New remote form GM 1 year old
Wheel sensors are o.k.
Old Sep 3, 2005 | 12:10 AM
Bill Dearborn's Avatar
Bill Dearborn
Wow that is a short distance. I can be a couple hundred feet away and my FOB still works.
Bill
Old Sep 3, 2005 | 12:20 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
hang in there, there's a link to fix the fob, involves soldering broken conn.(common prob)if i can find it, i'll post
Old Sep 3, 2005 | 09:56 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
It could be something broken as connecticut mentioned.
I'm assuming you have done the "Resynchronizing Your Transmitter" and/or the "Matching Transmitter(s) To Your Vehicle" procedures found in the owner's manual.
Sometimes that will help by "resetting" the remote.
The only other thing you could try is if you have a good relationship with a GM dealer you might get them to check it out for you.
Old Sep 3, 2005 | 10:26 PM
thevelvetglove
thanks ROCKnRoll,
I have done all of the above, with no sucess. In Hawaii it is show me the money first. That is why this forum has saved my thousands!! VBig A L O H A
Old Sep 4, 2005 | 04:40 PM
HIGHRPM's Avatar
HIGHRPM
Originally Posted by thevelvetglove
thanks ROCKnRoll,
The factory FOB is a POS!! Sooner or later most of them have problems. About 2 1/2 years ago a swapped the factory setup for a Clifford security system.... no more FOB problems... it also unlocks the gas flap from the FOB....
[URL=www.clifford.com[/URL]
HIGHRPM's Avatar
HIGHRPM
thanks ROCKnRoll,
The factory FOB is a POS!! Sooner or later most of them have problems. About 2 1/2 years ago a swapped the factory setup for a Clifford security system.... no more FOB problems... it also unlocks the gas flap from the FOB.... www.clifford.com
Old Sep 4, 2005 | 06:21 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi connecticut -
This might be the link you are thinking of -
http://www.iammoon.com/c5tech/fobs/
best regards -
mqqn
Old Sep 4, 2005 | 07:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You could have a bad Remote Function Actuator Module (RFA). For one function to work fine and not the other seems strange. Do you have more than one FOB and if so are both doing the same thing.
Bill C
Old Sep 4, 2005 | 11:32 PM
SteveDoten's Avatar
SteveDoten
Originally Posted by mqqn
Hi connecticut -
best regards -
mqqn
thanks for the link, ck the pic in the top right, the motion sensor prolly fell off, common prob, solder it back to the board
Old Sep 7, 2005 | 01:35 AM
thevelvetglove
[QUOTE=Bill Curlee]You could have a bad Remote Function Actuator Module (RFA). For one function to work fine and not the other seems strange. Do you have more than one FOB and if so are both doing the same thing.
Bill C[/QUOT
Thanks bill,
Yes it does it with both FOB. Do you know what my step is in resolving this nissue...
Old Sep 11, 2005 | 07:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the DTC codes in the DIC and see if there are any for the RFA or BCM. If there are, post the codes here and clear them. Sometimes when a code is set in the BCM and in some other modules like the TAC, the module will not function properly until the code is cleared. Here is a good link to what is what in the code world.
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
Hope this helps.
Bill
Old Oct 12, 2011 | 09:18 PM
thayward's Avatar
thayward
4th Gear
Default Changing battery causes honking!
Does anyone know what I am doing wrong? I change the battery in my key fob and program it, it works fine. Now every few minutes the car honks and I am not touching the fob. I went out and programmed it with the key in the ignition same thing happens. I took the fob apart and made sure all the pieces are put back secure, still I have honking. I have done this with both key fobs and they both do the same thing. What am I missing???
To Another FOB issue!!! aggrrrr
