code p0420 h c
Old Sep 7, 2005 | 10:00 PM
my1stvette.33's Avatar
my1stvette.33
2nd Gear
Default code p0420 h c
i have a 2001 6sp and just got code po420 again. car is completly stock and this code came up about 1 month ago. i cleared the code and drove. code came up again today. bad converter or o2 sensor? where are these sensors and can i swap from side to side without breaking the o2 sensor ( i have bad luck with rusted exhaust parts). does the emmissions warranty last beyond the 36 mo time frame?
Old Sep 8, 2005 | 12:19 AM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
I can't help with the tech, but I just did some warranty research; the emmissions warranty is only 2/24 vs the 3/36 for most other things. On an '01 it is long gone.
sorry for the bad news
Old Oct 1, 2005 | 08:23 PM
Greenbeast's Avatar
Greenbeast
I got this code p0420 in my 427 twin turbo lpe c5.
Before the engine got this code, I got the p0327 code.
The car does not making power after the engine warmed up.
Does anybody can tell me what´s going on??
Thanks for help!!
Old Oct 2, 2005 | 12:00 PM
Greenbeast's Avatar
Greenbeast
Thanks for help!!
Do I need to change the knock sensor and the catalitic in my case??
Old Oct 2, 2005 | 12:44 PM
boosted_z06's Avatar
boosted_z06
You need to check out the left side since its reporting a left CAT issue.
It could be a exhaust leak effecting the O2s making it then look like a CAT issue. Also could be a O2 problem, after about 30,000 miles they start to degrade and function slower.
ALL parts that are required by EPA for smog such as the PCM, CAT, 02 have to meet the 7 year warranty so if its a smog part do not let dealer screw you over.
To code p0420 h c
