Vararam filter problem solved
Old Sep 14, 2005 | 04:38 PM
Z06 Steve's Avatar
Z06 Steve
Default Vararam filter problem solved
I recently put on the vram and noticed that it created a slight hesitation during tip in so out came the baja filter.I took the baja and cut it up leaving the 2 foam gaskets still together.also cut the mesh wire but leaving the perimeter in place.I glued the smaller black foam gasket in place down towards the scoops section with the grey section facing up.I rtv'ed a K&N in place in the plenum and thats it.No more problem at tip in and it feels stronger.The 4 ply baja was too restrictive and sotp is obvious.Just thought i'd offer this mod as i'm pleased with the results and it looks clean.
Old Sep 14, 2005 | 05:12 PM
vetterlatethannever's Avatar
vetterlatethannever
Pics?
Old Sep 14, 2005 | 10:38 PM
Z06 Steve's Avatar
Z06 Steve
I'll take some pics but need someone to host them
Old Sep 14, 2005 | 10:40 PM
mowton's Avatar
mowton
www.photobucket.com
open a free account, submit pics, copy URL and paste into post; it's easy. I'll help if you want
Old Sep 14, 2005 | 11:07 PM
Z06 Steve's Avatar
Z06 Steve
cool i'll get on it tomorrow am.wait till you see this simple and effective set up.
Old Sep 14, 2005 | 11:12 PM
mowton's Avatar
mowton
Old Sep 14, 2005 | 11:33 PM
bigsal01's Avatar
bigsal01
we
need pics please
Old Sep 15, 2005 | 12:13 PM
tramminc's Avatar
tramminc
Originally Posted by bigsal01
weed need pics please
WEED did someone say weed?
Old Sep 15, 2005 | 04:31 PM
Z06 Steve's Avatar
Z06 Steve
Default pics are up
Old Sep 15, 2005 | 06:20 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Don't you know that the VR is a POS and causes engine failure, chronic fatigue syndrome, hair loss, erectile dysfunction and is not recommended by 4 out of 5 dentists that chew gum? jeeez.
Looks good.
Old Sep 15, 2005 | 06:27 PM
not08crmanymore's Avatar
not08crmanymore
Default v-ram
Looks good,Steve!i'll get a closeup when you do my visor.
Old Sep 15, 2005 | 06:33 PM
Z06 Steve's Avatar
Z06 Steve
Looks good.
thanks feels better too
Z06 Steve's Avatar
Z06 Steve
so thats 2 visors and 1 haz switch?
Old Sep 15, 2005 | 08:17 PM
ragtop1050's Avatar
ragtop1050
KN is coming out with one in a few weeks.That works with the VARARAM
Old Sep 15, 2005 | 08:46 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I'd love to see it.
Old Sep 15, 2005 | 08:57 PM
Z06 Steve's Avatar
Z06 Steve
It still wont work right the air box has to be modified.It might work after the VR3B is made.
Old Sep 15, 2005 | 10:27 PM
not08crmanymore
Default fix
so thats 2 visors and 1 haz switch? Well,if you have the time,you may as well do it all at once.
To Vararam filter problem solved
Old Sep 15, 2005 | 11:01 PM
Z06 Steve's Avatar
Z06 Steve
no problem.
Old Sep 15, 2005 | 11:21 PM
vetterlatethannever
So then they aren't coming out with one for the Vararam??
Old Sep 16, 2005 | 02:24 AM
Cscokd's Avatar
Cscokd
Steve,
I'm still confused about what symptoms you were seeing after you installed your VR that this mod fixed? Was it not idling properly or something? I didn't understand what you meant when you said tip in.
John
