Low Oil Pressure
Old Sep 18, 2005 | 02:14 PM
Torched Z's Avatar
Torched Z
Default Low Oil Pressure
I bought a new forged shortblock from a vendor and had a local shop assemble the longblock. They've installed it, but there is an oil pressure problem. The cold oil pressure is about 35 psi, but after it warms up the pressure creeps down to less than 10 psi. Once it gets below 10 we kill the engine to prevent any damage. I know GM says 8 psi is okay for 800 rpms, but I'm not happy with that at all. Here's what we've checked/replaced so far:
1.) Replaced oil pressure sensor to eliminate it as an issue.
2.) Checked O-Ring (it was fine) and replaced it
3.) Replaced stock LS6 oil pump with a new ported/shimmed LS6 pump to elimate it as a potential issue.
4.) Checked galley plug depth in back and it is in the correct position (not blocking flow).
5.) Checked plug in front of engine (it's there and not leaking).
6.) Oil pump spacers for double roller chain were on correctly (asymetric)
7.) Oil weight was changed from 10w-30 to 20w-50 with no appreciable difference.
Does anyone have an idea of what could be wrong? What else could we check? I'm not sure what the main clearances are, but I doubt they are that loose.
Old Sep 18, 2005 | 02:29 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
cam bearing clearance or crank bearing clearance.
Old Sep 18, 2005 | 03:16 PM
happa's Avatar
happa
Im having the same problem with my stock LS1. It hasnt dropedbelow 10 psi but came pretty close. I took it to the dealer and they said and some Forum members said its probley the heat. But I dont like it either. So if your motor is similiar to mine I would like to know how to fix it, I guess start over with a built motor . Well good luck and I hope someone can help both of us out
Old Sep 18, 2005 | 05:57 PM
mkern1's Avatar
mkern1
I had a problem with low oil pressure at high rpm and at idle. I ended up running straight 50 weight oil. (SAE 50) I then changed to a well known oil filter such as mobil 1 (m1-107), ac delco (upf 44), K&N ect. After changing the oil and filter my oil pressure problem has since dissappered.
It does seem like in your case that your bearing clearances could be causing the problem.
Old Sep 18, 2005 | 06:09 PM
MrEracer's Avatar
MrEracer
Is this a solid roller motor? Comp cams had a problem with solid lifters that caused low oil pressure in one of my engines. They are replacing a set of lifters that caused this problem.
Shirl
SD Racing Enterprises
Old Sep 18, 2005 | 08:28 PM
Torched Z's Avatar
Torched Z
This motor has the stock hydraulic lifters. If it was bearing clearances would we be hearing any noises?
Old Sep 18, 2005 | 08:49 PM
Evil-Twin's Avatar
Evil-Twin
No if the clearances are just slightly larger than spec, the oil (pressure) leaks from both the crank and the cam, because the bearings are not holding in the pressure... If you think about putting your finger over a hose nozzle, the tighter you hold your finger to the end of the hose the more pressure you feel... it could be one or the other, its possible they could have nicked a cam bearing or two in cam install...
Old Sep 18, 2005 | 10:40 PM
Cscokd's Avatar
Cscokd
make sure oil pickup tube is correct also
Old Sep 18, 2005 | 11:08 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Damn man.. that sucks..
My bets are on the bearing clearances.. sucks though.
steve
Old Sep 19, 2005 | 08:03 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
I had an ARE 347 and it had low oil pressure because of larger clearence.
i had the motor for 2 years, made a bunch of nitrous passes and the guy i sold it to is still running it with no problems.
i would just keep an eye on it, 10 at idle is fine and mine would run about 50 at wide open.
To Low Oil Pressure
