Help: Key Fobs Stopped Working
Old Sep 23, 2005 | 08:47 AM
jvp's Avatar
jvp
"Ask Tadge" Producer
Default Help: Key Fobs Stopped Working
Hey folks -
Just recently, I discovered that my key fob stopped locking and unlocking my C5's doors and hatch. I first figured the fob fell out of sync with the car, so I tried resyncing it. No joy. I tried a new battery. No joy. I tried my other fob. No joy. I tried reprogramming the fobs into the car. No joy.
I suspect the receiver is shot. The odd thing, it's the same receiver that the TPM uses. The TPM works fine. Do you think part of the receiver could have gone south on me?
What do folks think? Any ideas? Or should I expect to have to replace the receiver?
Thanks.
jas
Old Sep 23, 2005 | 10:54 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
what year car? If you have a window valet remove it before programming fobs to car.
Old Sep 23, 2005 | 11:25 AM
jvp's Avatar
jvp
1999. No idea what a window valet is.
jas
Old Sep 23, 2005 | 12:58 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Originally Posted by jvp
Hey folks -
Thanks.
jas
No joy, oops I mean jas,
Key remotes are very temperamental and sometimes there's no clear cut explanation.
My guess is the remotes are 6 years old and just from normal wear and tear need to be replaced.
If a vette buddy of yours has a passive design remote you could try to program his remote to your car.
Majority of the time when a member buys a new one his problem is solved.
Old Sep 24, 2005 | 12:24 PM
jvp's Avatar
jvp
Normally, I'd agree. But one of them has sat in a safe (with the car's title) for the last 6 years and hasn't ever been used. So it doesn't have any wear and tear. But it won't register with the car, either.
jas
Old Sep 24, 2005 | 06:03 PM
IamN2Speed's Avatar
IamN2Speed
I hadn't heard this before. I do have a WV, and have also had problems getting 'both' remotes to synch correctly. One will work fine, but the other never 'holds' the synch. Now that I read your comment, I assume it has to do with the WV. What specifically does this do, and what is the 'right' to do it?
Old Sep 24, 2005 | 07:09 PM
LS9's Avatar
LS9
just for kicks , have you changed the batteries ? Done a relearn ?
the batteries could be dead
Old Sep 24, 2005 | 08:08 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
jas
I've never heard of a receiver going "half" bad but I guess anything is possible.
It's possible the one in the safe could have a run down battery after 6 years. Take the new battery from the other remote and try it in your "safe" remote making sure you install it correctly. It's possible to install the battery upside down.
If you have a friend at a dealership you could stop by and get them to check it out.
Old Sep 25, 2005 | 05:41 AM
jvp's Avatar
jvp
Already done, and still no workie. And I made sure the battery was installed correctly. :-)
jas
Old Sep 25, 2005 | 11:53 AM
LS9's Avatar
LS9
any codes ?
Old Sep 25, 2005 | 02:24 PM
jvp's Avatar
jvp
Originally Posted by WHINER
any codes ?
An SCM code: B2605, which has to do with the driver's seat vertical sensor. There are no RFA codes at all.
jas
Old Sep 25, 2005 | 06:03 PM
dyal980's Avatar
dyal980
Mine was a loose Battery, Just Popped it on its backside and it went back to work.
Good Luck!
Old Sep 25, 2005 | 08:37 PM
edensknight's Avatar
edensknight
Loose battery was my glitch. But, you may have to replace the key fob and reprogram. These are small and sensitive devices that can fail. Good luck.
To Help: Key Fobs Stopped Working
