alternator install
Old Sep 28, 2005 | 09:00 AM
brunog's Avatar
brunog
Default alternator install
Any crazy things I should know about? Or just release the tension, un- bolt and bolt new one in?
Old Sep 28, 2005 | 09:14 AM
7LitreC5's Avatar
7LitreC5
Nothing crazy or difficult. I would didconnect the battery though...
Old Sep 28, 2005 | 10:10 AM
SpeedyZ's Avatar
SpeedyZ
Super easy on a C5! Like VortechC5 says, definitely unhook the battery! When you remove the bolts twist the alternator back and forth, it will push the bushings back making it easier to reinstall. Less than a 5 minute job on a C5, hardest part is getting the belt off and on!
Old Sep 28, 2005 | 10:39 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yep, that is pretty much it. But do unhook the battery. Look at Step One of my line lock install
here .
Old Sep 28, 2005 | 01:39 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Old Sep 27, 2014 | 02:31 PM
Cfiveornothing's Avatar
Cfiveornothing
Does getting the belt off require adjusting/loosening the tensioner pulley? If it does, what are the steps?
Old Sep 27, 2014 | 02:41 PM
lionelhutz's Avatar
lionelhutz
Tensioner is spring loaded. Put a wrench on the pulley bolt and rotate it then pull the belt off the water pump pulley.
Old Sep 28, 2014 | 10:45 PM
Cfiveornothing
Of course. I could i forget. I had a Chevy van years ago. That's How i replaced the alternator then. Thanks!
Old Sep 29, 2014 | 01:23 PM
Chicago1's Avatar
Chicago1
should take you 10-15 minutes if that
To alternator install
