HUD not centered horizontally
Old Oct 7, 2005 | 09:30 AM
skyman51's Avatar
skyman51
Default HUD not centered horizontally
When seated in the driver seat properly, the HUD on the windshield appears too far to the left. All adjustments work correctly,but it appears the projection unit itself is not properly positioned. Anyone had this issue?
Old Oct 7, 2005 | 10:42 PM
BanditDude's Avatar
BanditDude
I've noticed the same thing in my '02.
Old Oct 8, 2005 | 08:39 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
The projector really has no room to move in it mounting position inside the dash. I'm thinking the mirror in the projector, somehow, has become loose and moved....If thats the case, the projector will have to come out and be fixed/replaced. Good luck...
Old Oct 8, 2005 | 12:06 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I know it can be moved up/down w/ the buttons. MAybe you THINK you're seated properly but are actually tilted too far to the right in your seat????
Ron
Old Oct 8, 2005 | 03:06 PM
rockrz's Avatar
rockrz
Ron
I agree. Measure your buttcheeks and see if the left one is bigger than the right. If yes....have the left one shaved down or removed. Much cheaper than having GM work on your hud.
Old Oct 8, 2005 | 07:27 PM
Z28TOZO6's Avatar
Z28TOZO6
That's some funny $h!T. Good answer Rockrz
To HUD not centered horizontally
