Theory/Solution on Column Lock
Old Oct 9, 2005 | 08:28 PM
Jim2003's Avatar
Jim2003
Default Theory/Solution on Column Lock
Just a thought, (came to me after seeing the way people park), could the column lock problem come somewhat from pressure on the steering wheel. What I mean is; 1 - front wheels not completely straight when parking and turning off ignition so that the tire tread is not putting pressure on the column to center itself, 2 - hand pressure on the steering wheel pulling down on the side of the wheel when starting or turning off the igition, 3 - moving too fast with the key in the ignition switch either going in or taking it out. If the tolerances in the device are very small then any little pressure would cause problems with the release of the locking pin.
I do have an obsession with straight wheels on parked cars. I have noticed that in any car that I get into with the wheels turned the ignition switch is many time hard to turn. I have for years always parked (not just the vette all our cars) with my wheels perfectly straight and usually run back and forth a few inches just to get everything really straight.
Since GM cann't solve our problem we need to problem solve ourselves, so this is just for garage talk and thoughts. Yes I do know about the column lock bypass fix.
Old Oct 9, 2005 | 10:47 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You aren't the first one to speculate on this, nor will you be the last..
Yes, pre-loading the locking pin is not helping matters, BUT it will not (ultimately) absolve you of experiencing a CL failure.
The only known solution (since GM never redesigned the CL motor assembly) is to do the bypass mod.
Old Oct 10, 2005 | 11:35 AM
2kbluestreak's Avatar
2kbluestreak
I had a little problem over the weekend; got the "pull key wait 10 seconds" message and "service column lock". My 2k MN6 would start, but then shut off when I backed up a little. I believe the cause of this difficulty was the downpour of rain that must have got on the resisitor pellet in the key. I've had several experiences of wet keys fouling up my prevoius C4 and my present C5. It just seems that a little water on the resistor fouls up its reading by the computer so it refuses to start as it is programmed to do. What is interesting is that there seems to be a link between an incorrect resisitor reading and the column lock programming. I've had a CLB in for 5 years and have not been back to a Chevy dealer for the saftey recall. After a couple attemps to drive and the engine shutting down, I pulled the key, wiped it a little more drier, and waited 30 seconds. Then, she started up and I drove off as normal.
It seems like my computer was originally programmed to shut off the engine if it detects a malfunction in the column lock mechanism anyhow, which is what the recall is supposed to do with a reflash. And why would a wet key allow the computer to think there was a problem with the column lock?
Old Oct 10, 2005 | 12:11 PM
JC in XTC5's Avatar
JC in XTC5
Originally Posted by 2kbluestreak
IIt seems like my computer was originally programmed to shut off the engine if it detects a malfunction in the column lock mechanism anyhow, which is what the recall is supposed to do with a reflash.
The recall "enhances" the BCM logic to cover an additional case when the battery voltage is low and may not correctly detect a stuck CL, therefore the logic needs to account for this possibility and cut fuel.
The CL lock/unlock commands are triggered by the ignition key cylinder. There is a switch at the end of the ignition key cylinder that signals the BCM to lock/unlock the CL, so the problem you are seeing could be the cylinder/switch starting to have a problem (which is very common) rather than the key pellet (which would be the main reason for the Pull Key message). Just some input to consider.
Old Oct 10, 2005 | 01:41 PM
2kbluestreak
Thanks for the reply JC in XTC5.
Looks like another piece of the puzzle. We all need to remember to wipe our keys before putting in the ignition if our hands are wet.
To Theory/Solution on Column Lock
