Installing Headers
-=Rick
Some people have installed the headers without jacking up the motor and still others have installed them from the top by unbolting the steering shaft. Installing headers is not all that difficult, take your time, follow the directions for your headers and use LS1HOWTO.com instructions for ideas when things aren't going well. The LS1---- instructions contain torque values and nut/bolt sizes which my instructions did not have.
The most difficult thing on my install was attaching the wire harness on the passenger side so that it wouldn't contact the header. I attached two zip-ties thru the holes in the frame before intalling the header. I then attached another zip-tie to each of the these to hold the wire harness up.
I did have to loosen the starter motor. If you have to do this, tighten the starter motor bolts after the header is in place, but before you install the header bolts.
Also I would run a tap into the header bolt holes in the block, to clean up the threads before installing the new headers. 8mm x 1.25 thread pitch.
LG Headers, one thing I don't like about the LG's is the behind the CAT 02 Sensors are too far to the rear in the exhaust system for my liking. You could have some code issues with that setup if you're not careful during the install, maybe not. A lota folks like em and have had good luck with em, but the ones I heard of that do all have had the LG's installed by someone that does it for a living.
Bottom line, installing headers is work. It takes time and some determination. I've installed three sets of headers on my C5 and each time the install job goes faster and a little easier, but it's still work.
Again, put your Vette on a lift, have some help, and your project will be a lot less painful and time consuming
Good luck,
Cecil
German-American Corvette Club
Baden-Wurttemberg
Heidelberg, Germany
Hometown: Ft. Lauderdale, Florida
Born: Alexandria, Virginia (A long time ago
